Old 02-11-2002, 06:59 AM
dkrausz dkrausz is offline
Default I just tried a SRC experiment;
I’ve been working a lot at 48 x 16 because of this video project I’m on. Some of the material that I have done might go onto my demo CD. However, I really hate the way audio sounds after doing a sample rate conversion, but I did do a “tweak Head” SRC as a test with a 1 minute file (this took incredibly long...) So then I had a brain storm [img]images/icons/shocked.gif[/img] . Why not pull out the old Sony Mini Disc player that has been collecting dust for the last 2 years and try recording the original 48k file to it in real time through the analog inputs of the MD player?
So after doing the transfer, I opened a 41.1k session in LE. I imported the software converted file and then recorded the audio from the MDP back into LE via the optical i/o’s so that I could compare the sonic quality of the two files within the same 44.1k environment.
Now I realize that the MD format uses it’s own proprietary compression scheme but, let me tell you, the MD recording really did sound noticeably better than the software SRC I did within LE!! I couldn’t believe it.
Granted that both methods did not yield “fantastic” results when compared to the original 48k session master but at least it would appear that the MD alternative is a little bit less of a compromise when compared to a soft SRC, at least in my case.
The result of my test has me considering the possibility of purchasing a real time CD recorder for critical SRC’s. Might just be the way to go...
dk
http://homepage.mac.com/dkrausz
An experiment cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-07-2007 10:34 PM
A performance experiment... JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2005 09:35 PM
A little experiment edytnbch Pro Tools TDM Systems (Mac) 2 10-20-2004 12:27 AM
Experiment...? go i huvet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-18-2002 02:59 AM
An experiment... Kamurah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-12-2001 02:22 PM
