Too late to upgrade from PT10+CPTK?
I was unable to upgrade from PT10+CPTK to PT11HD before 12/31/14. I see I can still purchase it at Sweetwater for $599. I know by still running ML co-install is possible but I'm concern with surrendering my CPTK liscense and locking into the HD line. What happens if I just stay on PT10? The support plan is now good through 12/31/15 (three months less). Do this mean I won't get the PT12 upgrade? Anyone have any regrets who purchased this upgrade? Thanks!
Re: Too late to upgrade from PT10+CPTK?
What are your concerned about? If the upgrade is possible via SweetWater, then just go for it. It goes like this:
1) you surrender your old PT10 and CPTK licenses from your iLok 2) you transfer a brand new PT10+PT10HD+PT11+PT11HD bundle to your iLok I don't know but I think it should also activate the new support plan. And if you have active support plan, you should get the PT12 upgrade too. And then it goes like this: 1) you surrender your old PT10+PT10HD+PT11+PT11HD license bundle from your iLok 2) you transfer a brand new PT10+PT10HD+PT11+PT11HD+PT12+PT12HD bundle to your iLok There's nothing to worry about, surrendering old license(s) is required in order to get a new bigger bundle in place. And because there are multiple licenses, you can choose to keep using PT10 should you want to, and you have all the HD features too (no need for the old CPTK license).
Very well said. I just want to make sure my current PT10 projects will continue to work once I surrender my CPTK license. Here are my system details:
Mac Pro Quad Core -2.8 GHz Quad-Core Intel Xeon Memory 16 GB 1066 MHz DDR3 ECC MBoxPro 2 Mountain Lion 10.8.5 PT9/10 bundle + CPTK (running PT10.3.9) Ilok2 Mostly used plugins- Isotope RX4 Advanced, Waves Diamond. Thanks! |
As long as you can get the 64-bit versions of the AAX plugins you're already using, you should be fine.
You'll get a PT 10 HD license along with the 11HD license, so you won't have any issues with your existing PT 10 projects. I just did the 9/10 + CPTK upgrade through Sweetwater in December.
https://shop.avid.com/ccrz__ProductD...00&&store=shop |
Do I still have to upgrade to 64-bit AAX plugins if I'm just running PT10HD? I'd like to finish all my PT10 projects first. Thanks!
no
Manu PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup |
If your are currently using Pro Tools 10 and its working for you and you are in the middle of a project then you should change *nothing* except the assets on the iLok and you keep running with the new Pro Tools 10 HD license asset part of your Pro Tools 11 HD license bundle. And by nothing, I mean nothing, no Pro Tools 10 updates, no Pro Tools 11 installs, no touching plugins, no OS updates. What should be usual session/work in progress behavior--unless things are breaking. |
Another PT10 + CPTK to 11HD upgrade question... | Pirx | Pro Tools 11 | 17 | 11-09-2014 07:27 AM |
ProTools 11 upgrade from CPTK + PT10 | InquisyThorr | Windows | 2 | 08-13-2014 01:06 AM |
PT11 HD (from PT10 + CPTK upgrade) - can I drop in an HDX card? | bwherry | Pro Tools 11 | 9 | 12-14-2013 10:46 PM |
Any reason to upgrade from PT9 w/CPTK to PT10 HD Native? | dj_grimmace | Pro Tools 10 | 9 | 10-27-2011 03:54 PM |
