Re: Freeze Track Info
And wouldn't that be the case in every DAW then? Or have other's done it better?
Same is every other DAW. Can't freeze 'out of the box" tracks.
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
What I perhaps should have said explicitly is ... Therefore there is actually nothing for me in PT12, seeing as the whole cloud collaboration and marketplace stuff is irrelevant to me.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
thanks guys for the info.
If by "out of the box" you mean hardware inserts that is true, but, if you mean UAD plugins that is not true. You can freeze UAD plugins in other daws and it frees up the UAD resources while those tracks are frozen.
#16
I'm using UAD plugins with a PCIe card, and of course they freeze in my DAW. Why wouldn't they work? The system sees them as standard VST plugins. And in PT11 they are AAX. I would expect them to work in PT freeze track as well. If not, well that would be a very poor solution.
Dean |
#17
UAD PCIe is not "out of the box". Very much ITB. Standard VST and AAX plugins. Works very transparently in Samplitude.
#18
Just to further clarify my previous post...
In Samplitude the UAD plugins are treated as any other plugin. They work perfectly for Freeze track, offline bounce, whatever. A simple three minute mix with a couple of UAD plugins might offline bounce in as little as 5-10 seconds. |
#19
UAD and certain Waves plugs that use internal oversampling def slow PT's offline bounce down, that's for sure!!
#20
Most my UAD cause offline bounce to bounce at real-time speeds. Makes it completely useless.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
offline bounce from Send or Track outputs - track "freeze feature" | OliverH | Pro Tools 11 | 20 | 05-25-2014 04:45 PM |
Track-freeze? | rossi68 | Pro Tools 11 | 4 | 10-14-2013 04:36 AM |
Track offset menu or track freeze as workaround for ADC? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-27-2008 12:19 PM |
freeze track? | boot | Tips & Tricks | 5 | 07-05-2008 08:08 AM |
Track freeze? | wedgewedge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 03-13-2006 09:00 PM |
