  #21
Old 01-14-2015, 12:42 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: warp marker doesn't show up!
well i am sure you don't care to hear this but....with 10.9.4 and 11.2.1 i have the triangles....
Daniel
  #22
Old 01-14-2015, 12:47 PM
stargazerbass stargazerbass is offline
Ahahahah lucky you!
I'm hopless
  #23
Old 01-14-2015, 12:48 PM
YYR123's Avatar
Hey if that's the only problem your ProTools set up has well then maybe you're not so unfortunate
Daniel
  #24
Old 01-14-2015, 01:18 PM
Michael Zull Michael Zull is offline
I've had proper markers since PT 7.4 on Vista (or it might have been XP? I can't remember when I switched over)
Hopefully a reinstall will fix this for ya.
  #25
Old 01-14-2015, 01:21 PM
YYR123's Avatar
I don't quite go with the reinstall is gonna fix it - at least not in this one case....
That's the only problem he is having....idk it might be worth it to reinstall everything but I don't think it will
Daniel
  #26
Old 05-20-2015, 07:18 AM
djcl djcl is offline
Default I have the same warp marker flag / anchor issue!
I have the same issue. I spent an hour on the phone & sharing my screen with tech support and the issue was never resolved.
For me the issue seems to have begun with either the PT 11 update to 11.3.1.370 or the OS update to 10.10.3 (14D136). or a combination of the two.
I can add some info that may help.
The blue warp flags do not show up when I am using my MacBook Pro screen. I can place warp markers when editing on the laptop screen but, just like the original poster, they do not get a blue flag/anchor. However, when I attach an external monitor, the blue warp flags mysteriously appear! Likewise, when editing on an external monitor, the blue flag / anchors appear on the warp marker but when I remove the external monitor, the markers disappear again.
In the end, tech support claimed it was an issue with Yosemite and not PT 11 because PT 11 is not officially supported on Yosemite. However, the warp markers were showing up before on Yosemite.
I hope someone has a solution or the bug is fixed in the next update as it is very annoying. I am a DJ/Producer on tour using my laptop. Most of what I do involves using elastic audio. It is extremely frustrating to not be able to see warp markers when editing.
I hope this helps and thanks for letting me vent:)
MacBook Pro (Retina, 15-inch, Late 2013)
OS X 10.12.6
2.6 GHz Intel Core i7
16 GB Ram
Digi 003 Rack
Pro Tools 2018
  #27
Old 06-01-2015, 09:03 PM
Default Problem Also Exists in Pro Tools 12
Just a quick update.
I installed PT 12 on a cloned drive in the hopes that this bug would be fixed. Unfortunately, the blue flag is still missing in PT12.
OS X 10.12.6
16 GB Ram
Digi 003 Rack
Pro Tools 2018
  #28
Old 06-02-2015, 12:02 AM
PMF Media PMF Media is offline
Default
Is it a bug? I've never had the anchor flags appear automatically and that goes right back to 7.4... the warp MAKERS will display in warp view, but I've always ctrl+clicked the warp marker to anchor it, either that or quantise the clip and the anchors will appear... I'd just always assumed this was the normal behaviour
  #29
Old 10-04-2015, 08:54 AM
Good news! This issue has been resolved in PT 12.2.1 The blue triangle warp marker feet/flags are once again visible when using a MacBook Pro retina screen.
Thanks for everyone's help and thanks Avid for fixing this bug:)
OS X 10.12.6
16 GB Ram
Digi 003 Rack
Pro Tools 2018
Does ELASTIC AUDIO always leave artifacts on every warp marker P,B,S Pro Tools 10 5 01-23-2013 11:15 AM
Easy way to add warp marker to region boundary? EricWillhelm Pro Tools 9 1 12-09-2010 06:25 AM
Warp Marker Problem shultzee13 Pro Tools M-Powered (Mac) 0 02-07-2010 09:27 AM
Automatic warp marker placement without quantizing? FreqSabotage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2009 03:58 AM
unable to move warp marker Bart HLH Pro Tools TDM Systems (Mac) 3 10-09-2008 08:11 AM
