Re: warp marker doesn't show up!
well i am interested in this as well, I am currently upgrading a backup drive to 10.9.4 and 11.2.1.....
I am doing this as we speak, and btw the program I have is only up till PT10. I guess PT11 doesn't have a utility program.....
I think I'm going to save a copy of the session in an older PT format and after the warping I'll render and open it back again on the 11...hoping not having to change something back once there... |
I've uploaded a screenshot of the problem!
you can see from the pic that I'm in warp view( the darker lines are warp markers) and there's no "little flags" below the lines... |
those darker lines are already warp markers!
hope it explains better! |
Ah, I see, that's strange. I'll give my stock answer for when you start to see strangeness of this magnitude...do a fresh uninstall/reinstall of PT.
#16
I was considering about reinstalling everything but I'm not sure how to do it since there's not an uninstall option for the software(there's an avid articles on the knowledge base however)...but will I have to reinstall every plugins and saving presets ecc ecc, if I choose to do so? |
#17
Ya know, I'm not sure about that. It's been quite some time since I've done a PT-only reinstall. Every other time in recent years that I've done a reinstall it's been a fresh install of the OS as well, so I of course have had to reinstall my plugins. Hopefully someone with more experience with that can chime in here. I hope a reinstall fixes this for ya!
#18
thanks again! :) |
#19
I managed to get Elastic Audio to do something similar to what you're describing, and it's related to Samples and Ticks.
1. Select any audio Clip with material Elastic Audio can analyze (transients, periodic events, etc.). Make sure the Clip's track is set to Samples. 2. Enable Elastic Audio on the Clip. 3. Put the Clip's track in Warp view. Even if there are existing Warp markers in the Clip they will not display-only the Analysis markers appear. 4. Toggle the track to Ticks. The Warp markers will now appear. 5. Toggle back to Samples. The Warp markers will stay. It's worth a try to see if this method will give you your triangles back. Sorry it's not exactly what you're seeing. One other thing I noticed from your screen grab: The Track Samples indicator should be a tiny clock with a blue face, and I can't tell from the screen grab if it's blue or not. Probably not important. Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9 www.remotewest.com @RemoteWest |
#20
yes the timebase selector has a blue clock for the Samples! Thank you! |
Does ELASTIC AUDIO always leave artifacts on every warp marker | P,B,S | Pro Tools 10 | 5 | 01-23-2013 11:15 AM |
Easy way to add warp marker to region boundary? | EricWillhelm | Pro Tools 9 | 1 | 12-09-2010 06:25 AM |
Warp Marker Problem | shultzee13 | Pro Tools M-Powered (Mac) | 0 | 02-07-2010 09:27 AM |
Automatic warp marker placement without quantizing? | FreqSabotage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-15-2009 03:58 AM |
unable to move warp marker | Bart HLH | Pro Tools TDM Systems (Mac) | 3 | 10-09-2008 08:11 AM |
