warp marker doesn't show up!
Hi everybody,
I have a big problem within Pro Tools 11, basically when I use the elastic time feature I can't see the warp markers! The function is working but the little "blue flag" isn't there, the lines from the analysis just get a little darker. Anyone can help me with that? Thank you!!! |
Re: warp marker doesn't show up!
Specs of your system and pro tools version
thanks for the answer!
Mac Book Pro model 11,3 / 2.6 Ghz Intel core i7,/16 Gb ram / SSD SM0512F 500GB OSX 10.9.5 Pro Tools 11.3 .0 Digidesign Digi 003 interface ask for more if needed! |
So did you just upgrade to 11.3 recently?
I'm assuming you came from 11.2.1 or 11.2.2 did you notice those issues in those lower versions? Have you tried deleting preferences and restarting yet?
I upgraded to 11.3 hoping to fix the problem but nothing changed! I messed around with the preferences but I couldn't find a solution, what do you mean by "deleting preferences"? |
Search the user guitardom and in his signature is a link for a utility program that deletes prefs
If you have issues its a approved procedure by avid
mmmh looks like it's only a PC application!
I have one that's a Mac - version
Give me about 30min and I'll be home and can send you a link
btw thank you very much for the help! |
Does ELASTIC AUDIO always leave artifacts on every warp marker | P,B,S | Pro Tools 10 | 5 | 01-23-2013 11:15 AM |
Easy way to add warp marker to region boundary? | EricWillhelm | Pro Tools 9 | 1 | 12-09-2010 06:25 AM |
Warp Marker Problem | shultzee13 | Pro Tools M-Powered (Mac) | 0 | 02-07-2010 09:27 AM |
Automatic warp marker placement without quantizing? | FreqSabotage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-15-2009 03:58 AM |
unable to move warp marker | Bart HLH | Pro Tools TDM Systems (Mac) | 3 | 10-09-2008 08:11 AM |
