#21
Re: Why Did You Go For 11 Now?
I spent that last month suggesting that people NOT jump on the band wagon the instant 11 was released, and, for the last eon, I have been touting drive imaging and cloning as a backup plan that EVERYONE should have in place. I NEVER install any update or software(and I mean ANY) without saving a drive image first. I also keep a cloned drive with the last working version(10.3 since I have moved to 10.3.5). I have installed 10.3.6 and 11 on a separate system drive for experimenting, but all my day to day work is done on the 10.3.5 drive(swapping hard drives is not hard, especially if you run a PC and use a trayless SATA drive cage). Certainly, running partitions is another option that works. Having backup images and/or drives can save you from, not only a sour update, but it can save you from a complete drive crash too
I keep a pair of 2TB USB drives that hold nothing but drive images. I can roll back to PT9, LE8, XP with LE8..........i may never do that, but I CAN.....
#22
Albee I for one have ascribed to your suggestion like glue, and it saved my bacon more than once!
I like tinkering in PT11 now so I can get handy within it and get to know it - went from old school analog over the past 36 years to PT two years ago. Fear was replaced with humility and I won't look back! Your "harping" works! Thanks for all you do. Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
#23
I'm just in it for the laughs. |
#24
I believe they have to in order to keep the hackers out of your OS... a few of the last releases/updates were security updates to prevent hacking, etc... maybe small bugs, but basically just glad they are still ON IT.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
#25
Well as it Stands 11 seems to be the most stable version I've used Two thumbs up to AVID
#26
Needs some more plugs in there to get that trophy - so not just yet
#27
Agreed^^^
#28
Agreed as well.
#29
can't use my NI Komplete Revibe Sonnox Spectrasonics ....
Jimmy Makhaisingh Producer Mix/Mastering Engineer JimJam Studio iMac (Retina 5K, 27-inch, Late 2015) PT11HD HDX /HD i/o Magma Thunderbolt 2.0 Chasis 3T Manley Vari-Mu / MPassive Mastering version Sonnox bundle / McDsp / FabFilter / |
#30
My Gear Mac Pro (mid 2011) - 2x 2.8GHz Quad-Core Xeon, 16GB RAM, ProTools HD Native, UAD Quad. HD IO 16x16 + Lynx Aurora 16 Solid State Logic Matrix B&W 800 series + Yamaha HSM80s Mojave Audio, Royer, Neumann, Audix, Yamaha, AKG and Shure mics. Focusrite ISA828, SSL Alpha VHD, UA LA610-mkii, M-Audio OctoPre, Avid Eleven Rack Canare and Mogami cabling. http://www.boomsounddesign.com |
