  #21
Old 06-28-2013, 09:04 PM
necjamc necjamc is offline
Default Re: Any TDM hardware users able to run 11 as CoreAudio/ASIO?
Originally Posted by Eric Lambert View Post
Look at their stock since buying Digidesign 9 years ago. See the trend? On the left side of the graph you could replace "price" with "interest in their customers."
Not being nit picky, but Avid bought Digidesign in 1995.
  #22
Old 06-28-2013, 09:45 PM
Originally Posted by kelco83 View Post
Yes pardon me, the TB2 divides up pcie into 20 channels, of which, one device can use 2. Each channel is capable of transfer rates of 10 G/bit per second.
I am not sure where you get 20 anything from. Can you explain what you mean?
Nothing to do with Thunderbolt I can think of involves quantities of 20. Typical TB1 chipsets connect to 4 PCIe lanes and provide 1 or 2 TB output ports. The system designer can in principle hang as many of those chips off the system as you have PCIe lanes to connect the chips to. TB2 will change the details slightly but again nothing involves the number 20. Except the PCIe lane count on some obsolete Intel processors, which I am not sure would be relevant.
  #23
Old 06-29-2013, 08:06 AM
kelco83's Avatar
kelco83 kelco83 is offline
I don't do anything with thunderbolt, so my research source may be suspect, but here's my information.
http://en.wikipedia.org/wiki/Thunderbolt_(interface)
And is cited with http://developer.apple.com/library/m...011138-CH1-SW1
Data signal
Yes
Bitrate
10 Gbit/s per channel (20 total.)[4]
Protocol
4× PCI Express 2.0,[4] DisplayPort 1.1a[3]
Intel 4770K Hackintosh 16GB 128 SSD 770 GTX PT10 11 rack
Mac mini ivy bridge i5, apogee quartet, PT10, 11 rack
  #24
Old 06-29-2013, 08:19 AM
Data signal
Yes
Bitrate
Protocol
And what is your point exactly? All that is saying is that TB is 20 gigabit per TB cable (true for TB 1 and 2) not 20 channels total. Again there is noting in Thunderbolt that inherently split up the system into 20 channels. So is this the mistake--folks are reading that sloppily written wikipedia page as "20 total channels"?
  #25
Old 06-29-2013, 08:22 AM
kelco83's Avatar
My point is my understanding of thunderbolt comes from those documents, its not like I work with it. The cited apple developer article clears it up anyway.
I assumed it was 20 channels because in my hopeful mind there would be a way to get full bandwidth from a pcie slot in a cable. Yes, clearly I was dreaming. 40 gb/s is no where near 16 GB/s, so I assumed there was more left on the table. If I had done any type of math to check, I would have quickly found out 20 channels of 10gbs is actually faster than pci-e 16x lol.
Looks like pci-e cards will be a windows only thing in the future.
  #26
Old 06-29-2013, 09:34 AM
Eric Lambert's Avatar
Yes, you have it right. But Avid's presence stayed out of Digi's practices for several years. Digi felt like the same company. And then they didn't.
  #27
Old 06-29-2013, 10:46 AM
B.J. B.J. is offline
I remember Digidesign said it was impossible to get sound out of the internal speakers from Pro Tools, because of the "technical" things in DAE. Suddenly it was not…
Regards
b.j.
Originally Posted by Bharath View Post
Technical.
There are quite a few issues in the underlying code to support this mode (more so on Windows than on OSX). Couple of those issues needed a lot more development/testing effort and even after all that still end up with a (potentially unstable) 8 channel I/O.
Somebody above my pay grade made a (not so easy) decision to keep the focus on other things that went into PT 11.
Studio 1: Mac Pro 5.1/16GB/macOS 10.6.8/HD2/PT10.3.10HD, 192 I/Ox2, C24.
Studio 2: Mac mini M2 Pro/16GB/macOS 13.4/PT 2023.6 Ultimate/HD Omni/192 IO/DiGiGrid DLS/DiGiGrid IOX/Avid S3.
Mobile: MacBook Pro (16-inch, 2019) i7/16GB/macOS 13.4/PT 2023.6 Ultimate/Universal Audio Apollo Twin X.
Live: Avid VENUE | S3L-X System/Venue 4.6.1/Stage 16x3.
  #28
Old 06-29-2013, 10:53 AM
kelco83's Avatar
Regards
b.j.
I'm sure it wasn't sudden for the engineers that worked to get it to be that way.
My best guess is it had to do with the authorization through hardware checks. Once that was abandoned for ilok it was possible to open up PT to these other audio devices. Just my guess though.
Also, heh, if that pissed you off, wait till the new mac pro comes out and your current one bites the dust. WTF do I do with these pci-e cards?! (this is what you do, http://lmgtfy.com/?q=pci-e+chassis+thunderbolt crisis averted.)
  #29
Old 07-01-2013, 09:10 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Just a friendly reminder to make sure no one misinterprets this, you should make sure you are using the correct capitalization when referencing specs of Gb (Gigabits) and/or GB (GigaBytes). 1 Byte = 8 bits.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
PT9 with Digi Hardware: DAE or CoreAudio? lagasus Pro Tools TDM Systems (Mac) 0 11-13-2010 09:02 AM
Profire 2626 DAE or ASIO or CoreAudio audiogeekzine Pro Tools 9 7 11-06-2010 02:23 PM
Reason/CoreAudio/HD Hardware shadowbox Pro Tools TDM Systems (Mac) 5 07-21-2003 07:14 AM
new ASIO driver for 001 3rd party users? Adam Inglis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-02-2002 12:13 AM
Please ASIO driver for win98 users! ;) jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-22-2002 05:12 AM
