Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 12-15-2016, 09:10 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default New Win setup - HDio confusion
Guys and Gals - Cheers from Texas,
I just moved my whole setup to WIN10 and I am having some confusion on setting up my HDio.
It's currently in the 16 Analog in / 8 Analog out / 8 Digital in-out - Configuration.....
I am using my Digital card to run 2 AES inputs/outputs.
My Problem is ....on the first pic I was setting it up and I was going to put my 16 Analog inputs first "then" my AES in/outs (OCD?? Maybe).....but the first page is "only" showing me 16 in-outs. (Pic 1) (why wouldn't it show my 24in's? - That is 16 Analog and 8 Digital?)
As I understand it....it appears to be detecting my 2nd Analog card....and I can set that up just fine....but why doesn't the Digital card in's show up on the HDio setup screen. (Pic 3)
So I can set it up like the hardware setup screen shows (pic 2) but it won't show my 16 Analog ins
Am I crazy? do I need to take a break? thanks once again.
Daniel
Old 12-15-2016, 10:46 PM
Default Re: New Win setup - HDio confusion
Maybe I'm missing what you are trying to do, but the HD IO will only do 16 inputs and 16 outputs.
Old 12-16-2016, 12:34 AM
Neil H Neil H is offline
You can only use a maximum of 16io at a time per interface regardless of the physical connections you have.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 12-16-2016, 04:31 AM
YYR123's Avatar
Ok yes that is what I was trying to get at, it had been awhile since I had set it up on my mac....I must have run into this but I just didn't remember
16io limit....ok didn't remember that, maybe I assumed when they called it, 8x8x8 that I could get 24
Daniel
Old 12-16-2016, 03:01 PM
Misleading marketing perhaps .....did I just say that ? Oops
Sent from my HTC One_M8 using Tapatalk
Windows 10 Pro
Avid HDIO 8x8x8x remotedude Buy & Sell 3 05-17-2014 07:00 PM
Avid Pro Tools MP9 Audio Setup Confusion Uneik Windows 0 01-04-2012 08:39 PM
HDIo supports 32 in out? SNAZ Pro Tools 10 3 11-04-2011 02:12 PM
I/O setup confusion Talisker macOS 3 08-02-2011 05:24 AM
Audio MIDI Setup confusion scotty_perey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-29-2006 10:10 PM
