Old 11-07-2009, 12:11 PM
amayhem amayhem is offline
Default New to Virtual Instruments in Pro Tools
Okay so I'm not new to Pro Tools or Virtual Instruments in anyway. However, I am new to using them inside of pro tools. I have been using Reason, garage band and Fl studio for quite sometime now. That being said.
Which ones would you recommend for me to use? As far as I'm aware you can only use Rtas right? So does that illiminate alot of the sounds I would purchase at guitar center?
I do mostly hip-hop, rap, R&B and reggeton beats.
Just looking to see what are the best sounds you would recommend.
I am running Mac 10.5.5 and Mac 10.6.1 On both I am running Pro Tools 8 LE. Looking forward to hearing from you.
Old 11-07-2009, 12:15 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: New to Virtual Instruments in Pro Tools
If u use REASON, just keep using that via Rewire into PT... & that way u can use what u also have in PT as well...
CHECK THIS OUT
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-07-2009, 12:16 PM
RTAS is the supported Plug-In format for Pro Tools but VST can be used with a VST to RTAS Adapter.
If one VI currently that could cover a lot of bases I'd recommend Transfuser.
filosofem
Old 11-08-2009, 09:41 AM
RussUK RussUK is offline
filosofem
+1
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 11-08-2009, 06:17 PM
DonaldM's Avatar
DonaldM DonaldM is offline
It really depends on what you want to do. All the VI's that come with PT 8 are good and have great usefulness for different kinds of music. I like Xpand2 a lot and use it often. I also like Structure Free a great deal and Russ K and the AIR USers blog have made some unbelievable samples available for it.
ANd ou can use VST plug-ins with a VST wrapper program. Most here would recommend FXexpansion's VST Wrapper program. It allows you to use any VST plug-in or VI right in PT.
Pro Tools 10 and Virtual Instruments moniz.m Pro Tools 10 1 01-16-2013 01:43 AM
Using Virtual Instruments Pro Tools 10 - Please Help Me gclance macOS 1 02-23-2012 06:55 AM
Pro Tools 8.0.5 And Virtual Instruments jigga66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-27-2011 02:15 PM
Virtual Instruments for Pro Tools 6.4.1 on Mac OSX hotbeatz Pro Tools TDM Systems (Mac) 0 02-21-2008 12:42 PM
Virtual Instruments in pro tools at last! TheVectorWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-11-2001 11:46 AM
