probleme -6093 at the end of bounced
hello,
10 times of continuation I tried to bounce...nothing exceptional, just 6 tracks without plug-in!!! after few minutes (often at the end...arg! after 20 minutes...) I have a bug, this is : "the operating system held off interrupts for too long. if this occurs frequently, try increasing the "H/W Buffer Size" int the playback engine panel. (-6093)" Of course, I changed all of the possibilities in the playback engine but...nothing, always the same story!!! beurkkkk! I'm working on a G5 and a digi 002 if somebody could help me, you're welcome at home (no, no...no more 2 or 3...! ) |
Re: probleme -6093 at the end of bounced
I get that as well. I have increased the buffer size to the max, no help. It also tells me to delete tracks or reduce plug-ins. I routinely dump unneeded tracks and the only plug-ins I have are factory installed with PT LE 6.
I also sometimes get this while RECORDING, not even bouncing. I work on a iBook G3 (900) with 640 MB. There's plenty of room for the tracks I'm using. (spoken word under a minute each). |
System preferences>Energy Saver - set all to 'never'. Uncheck 'put hard disk to sleep when possible', then click on 'Options and make sure processor performance is set to 'highest'.
Problème clé Ilok et Pro Tools [Résolu] | MaxB88 | Le Forum en Français | 18 | 03-05-2015 07:26 PM |
Problème de mise à jour PT 10.3.6 | jihel | Le Forum en Français | 2 | 09-25-2013 01:26 AM |
PT probleme | Shevanelflip | Pro Tools 10 | 3 | 03-07-2012 07:59 AM |
Probleme with pro tool 8.0.1 | timestrike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-11-2010 01:29 PM |
S.O.S freezing probleme | davidS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-02-2000 11:42 PM |
