Re: Changed input routing since PhoenixVerb Surround v3?
Stratus (so I'm assuming Symphony too) does not have this bug. It goes to the center channel.
5.1 or 5.0 does not matter with either PhoenixSurround or Stratus. PhoenixSurround goes Left and Stratus goes Center in either situation.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Dumb question, but Frank, if you're on HD native, there should be minimal performance hit for using 5.0 sends instead of mono sends. Or are you forced to organize your sessions in such a way that they'll open up easily on HDX?
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
thank you very much for this straight forward, honest and transparent response. It's good to know it's now known as a bug and not wrong usage. I'm not sure why this flew under radar for so long. I noticed it when we continued to work on a series in a template from the previous season and everything seemed to sound slightly different but quite some time had passed since then and I wasn't sure if my memory fooled me till there was this reoccurring pattern of a lot of elements leaning towards the left. Anyway, thanks again for chiming in! Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
To make things worse, mono summing was bugged in all Protools versions 12.0 up to 2018.3. The summed signal was 3dB too low. This was fixed in Protools 2018.7.
@Michael, thanks for the clarification. Let's hope it will get fixed eventually. |
I just downloaded version 4.00 for a new Mojave install and the behavior is the same.
Scott Gatteño |
#16
Yes, everything from v3 onwards does it. v4 is just is the same as v3 with the Izotope re-branding added AFAIK.
#17
I have just tried sending a stereo buss and that goes to left and centre. However, if you pan the send hard left it feeds the left input of Phoenixveb,as expected, but if you pan hard right it still feeds left and centre, it doesn't do what would be expected and only feed the centre channel. There is clearly something odd going on with the input routing.
Bizarre. Mike |
#18
Digging through the release notes as I intend to roll back to 2.0.9 on all the rigs here, I see;
I hardly ever use Phoenix so I can't tell. Anyone got experience updating from v2 to v3 and loss of automation? |
#19
#20
After setting up a new system I experienced the same issue. Izotope support, unfortunately, is not very helpful. They told me that it’s a known issue but that they can’t help me. They described a workaround with 5.0 sends but that’s not really an option as frank described... Till now isotope doesn’t want to provide me with an earlier version of Phoenix surround. Does anyone know how/where to get the 2.0.9 installer for Mac? Best and thanks Paul |
FS: Exponential Audio Phoenixverb Surround and Excalibur Bundle | sonichead | Buy & Sell | 8 | 04-03-2020 03:49 PM |
PhoenixVerb Surround FS | Andy Hay | Buy & Sell | 0 | 01-13-2017 10:23 PM |
FS Exponential Audio PhoenixVerb Surround | The golfer | Buy & Sell | 4 | 10-31-2016 05:27 PM |
FS: PhoenixVerb Stereo+Surround, Waves Sound Design SoundGrid & more | Vytis | Buy & Sell | 8 | 09-19-2014 01:56 PM |
Routing input 5 from 002 to input 1 Amplitube Live | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-27-2004 12:56 AM |
