Old 07-25-2020, 01:06 PM
EVaschon EVaschon is offline
Default Syncing imported audio clips
SOMEONE PLEASE HELP ME!
I've been trying to sync an incredibly simple snare drum roll that is in 1/16th beat tempo to my existing project and everything that I read and find on YouTube tells me how to sync the ("track") to the music clip. Isn't that backwards? I want to sync the music clip to the existing track, not the other way around. If I do that, I'll be re-syncing the entire project to each and every new music clip I import. Surely, that can't be right.
I have tried the stupid "Beat Detector" (which seems to do nothing). I've watch the same stupid YouTube videos over and over, carefully trying to make certain that I haven't forgot a step and the end result is always the same - friggin nothing happens! This is my third weekend in a row just trying to figure out this one stupid thing. Can anyone help me since 90% of the time I will be importing pre-recorded instrument clips into Pro Tools and trying to sync them rather than trying to play every instrument.
Old 07-25-2020, 04:19 PM
Led Led is offline
Default Re: Syncing imported audio clips
You can use the tempo grid - put the snapping into slip mode, zoom in on the roll wav and trim the head right up to the very first audio, click on the clip and hit X. Put your snapping into grid mode, click at the beat you want the snare and hit V.
If it's not spot on, or isn't a tempo dependent thing just put the snapping into slip mode, and zoom in and move the clip around with the mouse till it sounds right. You can also set the nudge value up in the time display window to say 10 milliseconds and use < and > to nudge it earlier or later, then when it's really close change the nudge value to 1 millisecond to really fine tune.
Go by ear, things can look right and sound wrong.
Old 08-04-2020, 06:03 PM
Andy, thank you for your response. I do appreciate it.
Imported audio not moving into audio folder Nilreb Pro Tools 12 11 06-13-2021 10:20 PM
44.1 or 48 if audio is imported? audiofreak11 Pro Tools 10 9 06-05-2013 08:33 PM
Imported Audio Duplicating sweetambition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-09-2011 12:24 AM
syncing click to an imported track abbiehuxley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2008 08:15 AM
Imported Audio Syncing??? ronev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-29-2003 12:57 AM
