Re: Pro Tools 10 Field Recorder Workflow
Located a bug:
If I click on one of the files from the OMF I see listed an original TC. HOWEVER, if I look at the file in Workspace, the original TC is listed at 00:00:00:00. How can this be? When I imported files from the OMF I did a force to target format copy to make sure the files were .WAV. If I left them as OMF files they come up with no original time stamp and no user time stamp in the workspace. How is the clip info seeing the original TC, and not workspace? |
Not sure if it's the same problem that I had recently, but PT can be fussy with tape names in the edl, and this can mess up source timecode being passed correctly. If a tape name is too long or uses odd characters, all the source timecode reverts to 00:00:00:00.
cam01table05_001_new_01-15 Is it too long? Are underscores NG? is the - NG? Avid? |
Hard to say - bizarrely my issue was in the tape name metadata, not even visible in PT. It was a knock on effect. My fix was for the edit house to rename the tapes in MC then re-export the AAF. Took us days and days to track the bugger down...
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
#16
The FRW only works starting from referenced AAF or OMFs with external media… Greetings, Thierry
http://www.a-sound.com/ |
#17
Thierry - I'm 99% sure I've use embedded AAFs that have passed source timecode just fine.
#18
My guess is it's the underscores. |
#19
I have done numerous projects now with FRW. Both coming from Avid MC and Apple FCP7. During the years embedded OMFs have always been a problem carrying metadata over. So when we need to expand to original media, I always ask for a workflow with a AAF and linked external media. At this moment I'm doing workflow tests with FCP7 and PT11 for a future film project and again the embedded test OMF from FCP has all clips in PT showing TC00:00:00:00 (in this case probably a FCP limitation, that I have always seen happening) The Automatic Duck AAF with external media carries TC. PT through the years has been problematic with embedded OMFs an metadata. We still use embedded OMF and AAF for small/fast turnaround projects where no original sound rushes are needed, but often I see TC00:00:00:00 in the clips of such projects. Of course sometimes it has to do with wrong settings on the picture department's end, but on top of that AAF with external media has other advantages as well (no 2GB file limit problem, easier to go back and forth with picture department etc.) There still are dangerous issues such as the one mentioned here: http://duc.avid.com/showthread.php?t=345993 So while embedded OMF/AAF might work with carrying metadata, my experience is it often doesn't. YMMV of course… btw the problem in the thread might very well be a file naming issue as you point out. Greetings, Thierry
#20
I've never gotten sensible AAFs out of FCP, regardless of the settings. It's edl conforms for me if it's FCP.
Actualsize - if you can spot the clips on the timeline, it's definitely not the same issue I had. All my clips were offset from 00.00.00.00 (that being where the machine dropped into record), and there was no way of recovering the lost timecode within PT. Hope it's the naming issue and solveable though, these problems are so boring to track down. |
Field Recorder Workflow pls help! | jahtao | Post - Surround - Video | 4 | 03-27-2014 05:04 PM |
Film Production Sound Tips & Field Recorder Workflow with Pro Tools 9.0.3 | Tom Graham | Post - Surround - Video | 33 | 03-11-2014 01:42 PM |
Field Recorder Workflow & PT 9.0.2 | Tom Graham | Post - Surround - Video | 8 | 03-20-2011 11:39 AM |
Field recorder workflow question 2 | jahtao | Post - Surround - Video | 3 | 12-04-2009 06:11 AM |
