Old 04-04-2018, 02:19 PM
glamfolk glamfolk is offline
Default Re: New to Eleven Rack--interface not detected?
Well, Thanks, Benoni, for that checklist--I had tried everything on the list, but it looks like reloading the drivers and trashing the protools prefs was the ticket. Thanks for your help. The thing sounds great now! You're a huge help.
Old 04-04-2018, 05:01 PM
Benoni's Avatar
Benoni Benoni is offline
Great
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-10-2018, 09:52 AM
clubber clubber is offline
Originally Posted by Benoni View Post
Things to try would be to trash Pro Tools prefs.
Try a different USB port.
Try a different USB cable.
Try uninstalling the driver and install a previous version.
Try holding down the 'N' key while launching Pro Tools.
Does the Eleven Rack editor operate correctly?
Are you plugged directly into the computer USB port or a hub?
Have you tried disconnecting ALL other peripherals, restart the computer, and try with only the Eleven Rack connected?
Have you done the optimizations for Pro Tools? Things like turning off Sleep, etc...
I'm more of a Windows guy, so I'll ask some of the other MOD's who use OSX if they have any further ideas. We have to get this going!
Dear All,
I just got a second hand Eleven Rack.
It works fine as a standalone guitar processor.
Installed Eleven Rack v1.2.13 drivers
My PT Ultimate 2018.4.0 gave me an error when starting up (forgot to copy error message but I can reproduce if it will be helpful)
Updated firmware from 1.0.2 to 1.0.3
PT will still not start.
I am using a Mac Pro 5,1 with High Sierra 10.13.2
Tried different USB ports and cables.
It does not show up under Audio Devices in Audio MIDI Setup but I can see it in MIDI Studio.
I did not install the editor since I read it requires the paid update.
Let me know if you have any suggestions. THank you!
Old 09-10-2018, 11:57 AM
Benoni's Avatar
The error would be helpful.
Have you tried an older driver just to see?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-10-2018, 09:19 PM
Originally Posted by clubber View Post
Dear All,
If the Eleven Rack does not show up as an audio device under Audio/MIDI setup there is no point in trying anything with Pro Tools. It will be a driver or OS or hardware problem. The editor is irrelevant and yes not compatible with your old firmware.
Did you carefully follow the driver install instructions? Did you optimize your system for Pro Tools? (Pro Tools Install Guide)... Which includes disabling sleep/suspend in macOS?
The most common cause of the problem you are seeing is you have allowed the system to sleep or suspend while the Eleven Rack is connected and powered on. That will hang the driver. Try reboot your Mac.... does Audio/MIDIsetup now see the Eleven Rack as an audio device?
If that is not it we’ll look at the driver install next... and a possible full clean macOS reinstall... so ya betta hope it was just a hung driver
Using eleven rack with another interface DJ47 Eleven Rack 4 05-09-2016 09:34 PM
Eleven Rack as Interface Dopamine macOS 10 02-02-2013 11:35 PM
Eleven rack with another interface ? oplatner Eleven Rack 11 05-30-2012 07:33 AM
Eleven Rack vs. Eleven Rack to another interface petesteen Eleven Rack 1 02-05-2012 02:53 PM
Eleven Rack + Another interface? Kaigne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2009 06:49 PM
