Old 07-24-2014, 12:37 AM
peterle peterle is offline
Default BUG> Send doesnt mute when track is muted
At least on my Setup (current 10.3.8) PT HD and HD Accell 2
i have the following Bug:
I am using few AUX tracks for different microphones as inputs which i route
then to the recording track. Each of the AUX tracks has PRE FADER SENDS
which feed REVIBE on another AUX track.
When MUTING the AUX INPUTS (microphones) the PRE FADER SENDS
are STILL OPEN and feed REVIBE!!!
They should be closed too !!
So far i remember in earlier Version was everything as expected which
means IF AN AUX INPUT IS MUTED THE SEND IS MUTED TOO.
in the Hope it get fixed soon..
regards
foley artist , soundeditor
Old 07-24-2014, 01:32 AM
Craig F Craig F is offline
Default Re: BUG> Send doesnt mute when track is muted
it mutes if it is post fader, not pre
TB/FX are usually done post fader
Cue sends are usually pre fader
Thank you,
Craig
Old 07-24-2014, 05:13 AM
Drew Mazurek's Avatar
nope, always been this way. As it should.
Some analog consoles had internal dip switches which allowed this to be toggled, but the default behavior of PT is how it's always been done.
Why not feed the verb from the record track? Then, only the sent mic will get the verb.
www.drewmazurek.com
Old 07-24-2014, 06:57 AM
WernerF WernerF is offline
Just to concur, yup, pre fader sends do not follow the fader actions. That is why they are labeled pre fader. This behavior, as Drew has said, is common analog consol behavior unless a custom modification has been made.
Also, if you have any high latency plugins on those mic aux's you will feel the latency of those plugins when you are recording. If you record directly onto the audio tracks there will be no perceived latency. If this something that you already know and I am stating the obvious sorry for butting in.
Old 07-24-2014, 07:07 AM
As it "should" for some, but not for all. This infuriates me as it makes doing headphone mixes a PITA. I have been begging Avid to change or at least offer a preference for those of us that want pre-fade sends to follow track mute(just a simple check box in prefs would be a Godsend). Can't tell you many times I mute the scratch vocal and start tracking the lead, when the singers says, "I still hear another voice"......
Old 07-31-2014, 07:50 AM
lexaudio lexaudio is offline
It is necessary to function that way especially if you are creating a headphone mix and want to monitor and listen differently than the artist
However, I think what you are missing is that you can view the sends with mute, fader and pan on the sends view.
Goto the view menu, and under the sends assignment, click the send name, like Send A for example, and you will see it all.
So now you don't have to open each send fader to see if it is muted or not.
AVID won't change the way it works. This is what most of us do and it is simple and easy.
LEX
Ultimate 2018.7
MacPro 12 Core 3.46 - 10.13.6
128 Gigs RAM
EFI flashed 580 GPU
3 card PCI-e expansion chassis.
Avid Artist Control
Apollo 8 Quad, Satellite Quad, Octo Card
Cranesong Avocet Monitor System.
WireWorld ProAudio Cables
Old 07-31-2014, 08:13 AM
so this?: http://protools.ideascale.com/a/dtd/17689-3779
Thank you,
Craig
Old 07-31-2014, 08:24 AM
Emcha_audio's Avatar
I could find the option of muting pre-send aux at the same time as the channel beneficiary for those that needs it that way, but it should only be an option.
Manny.
Wave-T.com
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
how to mute a send on 003 console kt90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-03-2009 11:29 AM
Send Mute on Digi002? KingTor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2009 10:23 PM
headphone send muted by low latency? Arrgghh... Idahoguide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2008 07:12 PM
Bug: muted MIDI tracks still send controller data Philthy Pro Tools TDM Systems (Mac) 0 12-04-2002 03:45 PM
