Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-10-2009, 11:34 AM
ThaRemedy ThaRemedy is offline
Default Waves Multi Mono Plugs Only Effects Left Channel Now
I was recently workin on a new mix the other day and it was my first time using the waves plugin's since I upgraded to Pro Tools 8 so I dont know if the upgrade is causing the issue because now only the left channel is being effected by any waves plugin that I use. All the others are fine. Even in my older session's when they worked before its the same thing. Has anyone else got this problem?
Old 04-10-2009, 01:53 PM
Default Re: Waves Multi Mono Plugs Only Effects Left Channel Now
Check the plugins in question to see if the LINK button got disengaged.
Old 04-11-2009, 05:23 PM
Sardi Sardi is offline
Yeah I had this issue too. Was only certain Waves plugs, RenComp being one of them.
Once I upgraded to v6, the issue went away.
I did find though that if I opened an older session that already had the RenComp instantiated on a track, that it would link and work correctly. It was only when I tried to insert a new RenComp that the issue of non-linking would appear.
Upgrade to v6 and your probs will be solved.
Best.
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2005 01:01 PM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
