Old 07-03-2019, 08:05 AM
bassmagnetic bassmagnetic is offline
Default Shift + Rec (on S3) is not record arming track
With the preference setting in Eucon ticked "Rec/Auto Switch Press Changes Automation Modes", pressing shift+ rec doesn't record arm the track.
Doesn't seem there is a way to without the mouse ATM (it should with Shift press)
Old 07-03-2019, 10:31 AM
reichman's Avatar
reichman reichman is offline
Default Re: Shift + Rec (on S3) is not record arming track
Dumb question, but are you using surface Shift or Multi Select shift?
The surface Shift key in the hard left and right corners is the one you want. It should work.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 07-04-2019, 02:10 AM
doh
____slowly moon walks out backwards towards the door hoping no one saw me come in_______
thanks Nathaniel
awful sound when arming track for record BenDorigan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-09-2012 10:01 AM
Shift + Option + Record Enable not working with MIDI and Audio Track selected, why??? enzomolinari Pro Tools 9 0 07-20-2011 07:00 AM
Arming Channel Record Button on Protools LE timbre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-12-2010 06:20 AM
monitoring without arming record Allen Tucker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2005 01:43 PM
Track Arming AJ-D450 DVC-PRO PHead14006 Post - Surround - Video 2 01-21-2002 10:58 AM
