Old 02-16-2001, 10:03 AM
dave23 dave23 is offline
Default Re-install or restore, and what is a \"clean install\"?
Hello,
My DP G4 500 has become very crash prone so finally I dumped PT LE 5.0.1 until 5.1 arrives and I'm going to re-install OS 9.0.4.
1. I have two Mac OS disks that came with my system: install and restore. I have a good idea what each does but which would be better for me to set up a stable G4 running just music apps and maybe Netscape so I can download when I need to? WIll I be without a browser if I do Install instead of Restore?
2. Also, do I need to buy anything or do anything special in order to do a "clean install". I was just going to back up key data to DVD-RAM, trash everything, and either Install or Restore. Which is the clean install, or do I need something else?
thanks,
dave23
Old 02-17-2001, 12:00 AM
ZA ZA is offline
Default Re: Re-install or restore, and what is a \"clean install\"?
dave23,
Try disabling all 3rd-party extensions. If that helps, start enabling them one by one until you start crashing again.
You should also try disconnecting USB devices and anything else you added recently.
Run DiskDoctor.
Reinstalling the system is a last resort, if system files are deleted or corrupted. It is also a fool-proof way of getting rid of 3rd-party software. If you feel comfortable checking these things "manually" it's a lot quicker.
If not, use the Install disk. Back up your files. Start up from the Install CD and put your old System Folder in the trash before running the installer, to make sure you're getting a fresh System Folder.
I probably go overboard here, but better safe than sorry. Good luck.
--za
Old 02-17-2001, 11:26 AM
KennyB KennyB is offline
I would suggest that a "clean install" requires that you first initialise the hard drive that you are going to install your system on to.... Thats how we do it here.
Old 02-18-2001, 06:41 PM
372cat 372cat is offline
Neil Ward posted this excellent link on the DUC some months ago. It was invaluable in helping me set up a no-nonsense custom extension set for my G4 500/ Digi 001. I hunted it down and am sending it on in the hopes that it will do the same for you. www.logicuser.net/extensions/browse.php3 Also, when you get to the brink of a complete clean re-install, check your dilog box for the restore in place option. This WILL reinstall your system software but WON'T touch any files (software, etc.) that you have accumulated on your drive. It has worked for me, but I would urge you to run it by someone smarter than me (almost anybody!) before taking the plunge. Good luck!!! Jerry
jerry
www.proguitartracks.com
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
Clean install of PT 10 under fresh install of Lion bortraws macOS 0 10-24-2011 08:53 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Restore-Install PTLe8 & plug ins henno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-14-2009 04:06 AM
Install 5.1.1 le from 5.1 ? clean install or what? cane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-02-2001 08:02 AM
