Old 01-03-2014, 10:25 PM
gerry c gerry c is offline
Default HELP I'M IN DRIVER HELL! "The application failed to initialize properly (0xc0000005).
I have an original mbox and have been using it with PT 7.4 on a windows vista home edition 32 bit laptop with no issues. About a year ago I got the infamous error "The application failed to initialize properly (0xc0000005). Click OK to terminate the application." I have uninstalled and reinstalled a hundred time and the same error pops up. Since then...
1. I have tried at least 6 different usb cables.
2. I have no third party plug-ins.
3. I unchecked compatability mode as recommended
4. I have run cc cleaner and regcure countless times.
5. I have uninstalled just about every program that did not come with this laptop
6. The lights all appear normaL on the interface
I am 50 hours in and I am hoping that someone has the magic answer. I have read countless forums and followed all the recommendations, I have no idea why it suddenly stopped working. PLEASE HELP !!!!!
Gerry C !!!
Old 01-03-2014, 10:45 PM
Default Re: HELP I'M IN DRIVER HELL! "The application failed to initialize properly (0xc00000
Also after each installation I can see in the driver "Dalwdm.sys" in the driver folder and when I go to my device manager The sound, video and game controllers folder shows "digidesign mbox" and when I click on the icon it says "the device is working properly"
I'm stumped
Gerry C !!!
Old 01-03-2014, 11:10 PM
Have you made sure that windows is not attempting to use your mbox as the system sound playback device?
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-04-2014, 01:17 AM
I don't think so. The computer speakers are on whether the mbox is plugged in or not. I'm still at it. and I'm truly stumped.
Gerry C !!!
Old 01-04-2014, 01:18 AM
How do I make sure taht this is not the issue?
Gerry C !!!
Old 01-04-2014, 01:20 AM
I just checked my drivers folder and the driver version I have is 7.4.0.309 if that helps.
Gerry C !!!
Old 01-06-2014, 06:17 AM
popajoe popajoe is offline
hi's this will help you go to device manager an disable all audio device but your m-box there under sound's then reboot an tri to open pt .
Old 01-06-2014, 06:27 AM
soybalm soybalm is offline
If it's only 50 hours, you might be able to do a restore point to restore the computer to the state it was in when everything was working. System restore is in the control panel for Windows.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 01-06-2014, 08:22 AM
zolko
Guest
Posts: n/a
Sounds like old bad DEP problem for me... When I put phrase "The application failed to initialize properly (0xc0000005)" to google I got very good anwers. "DEP fix" was also very good described on this forum, answerbase etc.
Pro Tools 7.4 failed to initialize properly(Oxc0000142) Kentjm Pro Tools 10 2 07-13-2012 03:49 PM
Keep getting "application failed to initialize properly 0xc0000005" georgeearth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-23-2011 08:16 AM
application failed to initialize properly (0xc000001d or 0xc0000142) graveleye Pro Tools M-Powered (Win) 4 04-12-2011 05:58 PM
THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005) scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-17-2009 05:01 AM
Program failed to initialize properly (0x80000003) JonHallur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-12-2009 05:40 PM
