Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-30-2013, 07:30 PM
bd0319 bd0319 is offline
Default No Sound w/ Dante Virtual Soundcard
I am running a Dante Virtual Soundcard on an iMac with Pro Tools 11. I know that the DVS is working properly and patched correctly because I am receiving signal in another DAW on this computer. But, it doesn't matter what I do, I cannot get anything in Pro Tools. The I/O says aggregate devise, and I can't find anywhere to change that. In the Setup App, under Hardware Setup, I have changed the audio source to each option, but nothing helps. Does anyone have any ideas of what might fix this problem?
Old 12-30-2013, 08:54 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Re: No Sound w/ Dante Virtual Soundcard
In the aggregate I/O set up, did you check the input/output assignments that you want Protools to see? you have to make sure that either the DVS is set as the lone interface, or included as part of the aggregate I/O assignments. I had the same problem and it took forever to figure it out.
Also in the DVS set up, I have found that you need to select the 32x32 options for Protools to recognize the DVS (assuming you have the regular version of PT and not an HD version).
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group: Speechless tour
Home/mobile: Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Focusrite Red 8Pre / Protools HD Native 2018.10 Ultimate
Old 12-31-2013, 06:16 AM
If I can get protools to recognize the DVS in 32x32, will it ever allow me to record 48 DVS channels, or would I need to upgrade to Pro Tools 11 HD for that?
Old 12-31-2013, 07:51 AM
junkgear's Avatar
junkgear junkgear is offline
Is the DVS selected in the Playback Engine settings?
You need to change it there before you do anything with the I/O settings.
Will K
System Details
Old 01-01-2014, 09:25 PM
That worked, and I can now record 32 channels, but occasionally it switches from the DVS to the aggregate devise when I launch Pro Tools. Is there a way to prevent that? Also, is there a way to record more than 32 channels at a time this way?
Old 01-01-2014, 09:46 PM
Hold down the N key when starting Pro Tools. Or delete the aggregate IO device entirely in Audio/MIDI setup.
Nope on channels. Pro Tools is limited to 32 with an Core Audio interface.
If you want to play with Dante with more you channels need to come in via a Focusrite Rednet 5 Dante Interface into a HD Native or HDX card or you could also use a MADI bridge to MADI HD (likely less practical and more expensive).
Old 04-16-2017, 04:49 AM
igetnosleep igetnosleep is offline
Hi Guys,
I have been trying to sort a similar problem out for a few days. Pro tools can see DVS and all my outputs are working, but I can't seem to get an input. I've checked though my PT I/o settings and the routing of Dante Controller and as far as I can see everything look correct. Any suggestions?
Thanks,
Tim
Old 04-16-2017, 08:42 AM
Originally Posted by igetnosleep View Post
Hi Guys,
Thanks,
Tim
Not much info here. Folks here cannot guess what you think "looks correct" is. How about posting shots of playback engine and IO input/output/bus dialog panels and the IO selectors on say the mix window track you are trying to use. And what input from what interface, what mic/DI box etc., recording what exactly to what track? And what debugging have you done to confirm there is a signal present at that input... (can you monitor it through hardware monitoring for example).
What exactly did you do for a few days? Trash prefs? Default all the IO? Try a new empty session? Reinstall any software? (those are the pretty standard steps you should have tried).
Old 04-16-2017, 01:35 PM
I am using a red 4pre connected to my iMac running PT 12.7 on OS X 10.8.5.
here is a screenshot of the Dante controller set up:
I am running DVS in 32x32 and have selected DVS as my playback device on PT:
I/O on PT is set to its default, see pics below:
and my inputs on mix window:
I can see I am getting my input from the meter on my red 4pre and all inputs are working when I am using it via Thunderbolt on my MacBook Pro. I then change the set up to Dante and swap to my iMac.
On the iMac I am getting all my outputs, just not my inputs. I have not ran any re installs, I wanted to check first I am set up correctly in the patching or if there are any common mistakes other users had encountered.
Hopefully this is enough info
thanks
Old 04-17-2017, 03:57 AM
got it sorted, I didn't have the inputs correctly routed on the Focusrite Control.
thanks for the help
Tim
Soundcard as sound input Starting User macOS 4 02-13-2013 01:05 AM
Dante issues with PT 10 AnthonyDW macOS 3 10-08-2012 03:48 PM
HELP!! I can't get the sound to work from my Dell soundcard. jwrivers Windows 1 08-29-2011 01:51 AM
Mbox as soundcard for Macs out sound jensensense General Discussion 0 09-04-2007 03:24 AM
Problem using PT SoundCard as default Sound device toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-13-2003 10:30 AM
