Old 02-05-2013, 06:10 PM
Reesho Reesho is offline
Default How to save half speed playback?
I know that shift-spacebar will play an audio track back at half speed. Is there a way to record that half-speed playback? Simply busing the track to another to record only yields the original waveform.
The reason I want to do this is to recover some old reel to reel taped audio which was recorded at a slower speed than my user machine is capable of playing back so that they get recorded at double-speed. Am I making sense? lol
I guess I can always shove a mic in front of the speaker.....
Mac Pro 2x2.8 Ghz Dual Quad-Core Intel Xeon
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Midi Controller =M-Audio Axiom 49/USB2
Old 02-05-2013, 06:22 PM
Default Re: How to save half speed playback?
OK Never Mind. I just found out that I can use the Pitch Shift audio suite plugin. Works great! Can't figure out how to delete my original post though. Ah there's always a question I guess.
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Old 02-06-2013, 04:42 AM
Ben Jenssen's Avatar
I never used pitch shift plugins much, but I once found a way to do it with very little quality loss.
I wanted to speed up a session with audio tracks, and pitch shifting resulted in rubbish quality. So I exported all the files with a bit lower sample rate, imported them into the session again without sample rate converting, and they played back faster. Losing very little quality.
If I wanted to go from 100 bpm to 110 (10%), that would mean saving a 48 khz file as 43,6 khz. A little tricky math here, it's easier when you wnt to slow things down.
In your case Reeso, you could just record at 96khz and import them to a 48khz session, without converting.
Old 02-06-2013, 08:52 AM
Thanks for that info Ben!
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Jerky half-speed playback in PT 10 JWalkerPostAudio Post - Surround - Video 9 03-20-2012 05:25 PM
PT8 half speed playback, what the?! therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-20-2008 03:38 PM
half speed playback help crushed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-29-2007 01:18 PM
Half Speed Playback Crash dvo Pro Tools TDM Systems (Mac) 0 11-02-2004 08:11 AM
No half-speed playback Sonny Pro Tools TDM Systems (Mac) 0 02-25-2000 11:01 PM
