Old 12-28-2012, 01:20 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Upgrade to PT10 or Memory upgrade
For samplers/VI's you are dealing with both CPU and RAM... and the RAM limitation of 4GB applies since the VI's are hosted directly in Pro Tools.
In addition to the amount of samples that a VI loads into RAM, it will probably also take up somewhere between 128MB-512MB of RAM, sometimes more depending on the VI and how many instances of it you are using. You can look in the activity monitor app to see how much RAM each app on your system is using. Try opening a blank session in pro tools, then add VI's to it and load some samples, you will see the amount of RAM pro tools is using increase as you add more samples and/or VI instances.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
PT10 from PT9 upgrade with free PT11 upgrade curlydog Pro Tools 10 4 05-10-2013 08:32 AM
How to reinstall PT10 if PT10.3.2 upgrade failed? Martin11 Windows 12 12-09-2012 03:16 PM
Memory upgrade darkglass Pro Tools TDM Systems (Mac) 5 10-05-2009 09:01 PM
memory upgrade Jonah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-17-2003 12:41 AM
The best memory upgrade MB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2000 11:56 AM
