Old 12-19-2011, 04:24 PM
12bbb 12bbb is offline
Default DIGI002 and 8pre in PT9
Can I use both units at the same time?
Motu 8pre PT11
MacPro
2 X 2.8 GHz Quad Intel Xeon
6Gig memory
1 X 320gig HD
2 X 80gig HD
Old 12-21-2011, 04:45 PM
Default Re: DIGI002 and 8pre in PT9
any help?
Motu 8pre PT11
MacPro
6Gig memory
1 X 320gig HD
2 X 80gig HD
Old 12-21-2011, 07:41 PM
nst7 nst7 is offline
What is the 8 PRE?
Old 12-22-2011, 04:42 AM
Motu 8pre
I wan't both available ( 8pre and 002 )at the same time in PT9.
Motu 8pre PT11
MacPro
6Gig memory
1 X 320gig HD
2 X 80gig HD
Old 12-22-2011, 07:10 AM
ifix ifix is offline
I use a 003 and 8pre at the same time in Pro Tools 9, and I guess you can do it the same way as I do. The 8pre is connected to the 003 via an optical ADAT cable and it works like a charm. Just make sure you set the clock source to optical in the hardware setup and add eight mono tracks in the optical section of the I/O Setup. If this doesn't work you might have to do a firmware upgrade on the 8pre in order to make it work. I had to that when I got mine.
Old 12-23-2011, 05:22 AM
Thank but I know it work that way. I wanted to have them both direct into PT9 . By Firewire. To have the both seperatly available.
Motu 8pre PT11
MacPro
6Gig memory
1 X 320gig HD
2 X 80gig HD
Old 12-23-2011, 06:41 AM
Maybe you can do it with the Pro Toools Aggregate I/O? But why do you need to use it the way you describe?
Old 12-23-2011, 07:11 AM
You will not be able to do this, because the 002 and 003 series interfaces do not aggregate with any other devices.
MOTU 8pre Dvargas Pro Tools 9 9 03-15-2012 12:16 PM
Is it possible to use a Motu 8Pre with ProTools? bobtastic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2008 10:49 PM
Using MOTU 8pre with 002 hutchypie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-10-2008 05:28 PM
ARX 8PRE vs SM PR8 protoolsman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-18-2002 01:21 AM
ARX 8PRE vs SM PR8 protoolsman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-17-2002 11:05 PM
