Old 02-12-2008, 04:12 PM
DarylBham DarylBham is offline
Default Medium and Long Delays
How do you all use and setup your delays with or with out auxilary tracks on vocals or even other instruments? Just trying to get some new ideas
Old 02-12-2008, 06:15 PM
Default Re: Medium and Long Delays
9 out of 10 times, I insert the delay plugin on an aux track and use an aux send/buss to send things to it(make sure the mix is set to 100% wet). The exception for me is when I want to take a mono single track and make it sound wider. In that case, I will often insert a mono-stereo delay plug directly on the track.
Old 02-12-2008, 09:38 PM
Souf Centrol Souf Centrol is offline
I usually use them on chorus' when I want it like ole dude said wider
http://www.soundclick.com/soufcentrol<~~~Check out some of my music
Old 02-13-2008, 08:10 AM
"ole dude"...aw man, I've been cut to the bone! LOL
Old 02-13-2008, 12:42 PM
IntelDoc IntelDoc is offline
Ya, "ole dude" is pretty good with it. I tend to have all FX on a aux (stereo or mono) and then from there have my delays go to other fxs with busses from there. So send the sound to a delay, send that out on a buss to a eq and filter it out, send to a flange, etc. Just adds textures to the sounds and some cool qualities if done properly.
Ole dudes rule.
Doc
MONUMENT SOUND
MONUMENT SOUND ON REVERBNATION
Monument Sound Facebook
"Changing how people hear music one track at a time"
Old 02-13-2008, 04:04 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
I usually will send out to an aux track.
I always filter my delays huge. At about 300-400hz HPF and at 4500 hz LPF This will clean up the vocal mix huge. No sibilants on the vocal delay and it also allows the vocal breath on the bottom end. Sometimes I will also scoop more out of the delay as needed too.
And like the Doc said, sending the delay bus out to modulation is not a bad idea either. The field is endless if you will
Sign up for all things....AWESOME!
Kris
May the music move you
Old 02-13-2008, 04:55 PM
Thanks all, i appreciate all the thoughts and ideas, very much so.....
Delivery Medium for Pro Tools 10 HD SpongeBob Pro Tools 10 6 12-31-2011 12:49 PM
RAID safest magnetic medium for Long Term Archiving? spiritG Pro Tools TDM Systems (Mac) 5 11-18-2010 01:23 PM
long delays when using workspace & audiosuite? Sunzate Pro Tools TDM Systems (Mac) 6 04-05-2010 11:08 PM
Weird Problem after switching from Short to Long Delays ADC 25ghosts Pro Tools TDM Systems (Mac) 8 03-23-2009 01:48 PM
long sync delays in OSX Syncman Post - Surround - Video 2 11-22-2003 11:51 AM
