Old 11-07-2016, 08:56 AM
Obijuan Obijuan is offline
Default MIDI editting while looping
How could I edit just one midi note in the Edit Window while my song is being played in a loop mode?
When I select a part of the song in order to play a loop and then i open the midi Editor window, all midi notes are selected, so when I try to move one note, all notes move in the same way. If i select just the desired note I loose my loop. I cant find a solution to this.
I would appreciate any help
Regards
Old 11-07-2016, 04:32 PM
Ben Jenssen's Avatar
Default Re: MIDI editting while looping
Hi. Sounds to me like it's a matter of turning off "Link playback and edit selection". Options menu or prefs... can't remember now.
Old 11-07-2016, 05:21 PM
anothercolour anothercolour is offline
I always use Dynamic Transport Mode; it decouples the playback location from the timeline selection (command-control-P on MAC).
Editting Midi Takes in a Playlist View? asounds Pro Tools 9 2 09-12-2011 12:06 AM
Editting between ticks carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2011 01:02 PM
Midi Looping Flpalla Pro Tools M-Powered (Win) 3 03-07-2007 01:21 PM
MIDI Looping Problem, Help!!! DeNiro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-22-2006 09:34 PM
Midi Looping Chompers MIDI 2 02-14-2001 10:56 AM
