Old 04-16-2010, 10:12 AM
SamuelAdams SamuelAdams is offline
Question Need DDR3 Motherboard Built in Firewire Whom Have Had Success With
Need Advice With Those Who Have Had Success With a DDR3 Motherboard WITH BUILT IN FIREWIRE
Need it to have 4X240pin ram slots,
Core2 Duo Acceptable - CPU Socket Type LGA 775
FORM FACTOR ATX
CORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) COMPATIBLE
I believe my motherboard is at fault for an unsuccessful pro-tools no one can seem to fix my problem, here is the motherboard i have http://www.newegg.com/Product/Produc...82E16813128414
CPU Type Core 2 Extreme processor/ Intel Core 2 Quad processor/Intel Core 2 Duo processor/ Intel Pentium processor/Intel Celeron processor
FSB 1600(O.C.)/1333/1066/800MHz
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR3 1600/1333/1066/800
Maximum Memory Supported 8GB
Physical Spec
Form Factor ATX
Power Pin 24 Pin
and here is my posted topic on the problem im having http://duc.digidesign.com/showthread.php?t=271332
Old 04-16-2010, 12:54 PM
sunburst79 sunburst79 is offline
Default Re: Need DDR3 Motherboard Built in Firewire Whom Have Had Success With
FORM FACTOR ATX
Memory
Physical Spec
Form Factor ATX
Power Pin 24 Pin
I've forgotton what the exact difference is between a P45 and a P43 chipset but the P43 is a "Binned" part meaning that its a P45 that didn't meet spec and has had some features disabled. I would recommend a board with a P45 chipset first.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-16-2010, 02:32 PM
DJ Hellfire DJ Hellfire is offline
Maybe using the "built in firewire" is your problem. Go to guitar center. They have Digi Approved Pyro FW PCI cards for $40. Got mine for $20 on clearance. I'd try that before replacing the motherboard!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 04-17-2010, 01:47 PM
no i said built in because im using a digi approved firewire card, i had a digi tech support guy take over my computer and he tried for several hours to get it to work, i tried everything he said and more, he concluded he has never seen a problem like this before and i should prob just get another motherboard.
Old 04-17-2010, 05:33 PM
Oh, ok. The "WITH BUILT IN FIREWIRE" emphasis threw me off! I just did a build last week that was succesful. I used this mobo: http://www.newegg.com/Product/Produc...82E16813128423
Pro Tools 2021.12
Old 04-17-2010, 05:52 PM
rqstudio rqstudio is offline
Sorry if this has been touched upon but, are you sure (in disk allocation) you're never writing to your system drive?
www.rickqueststudio.com
Old 04-17-2010, 06:02 PM
He's looking for a Socket 775 board though.
Scott
Core 2 Specs Page
Old 04-23-2010, 08:14 AM
can you link me this firewire card sir? i dont want to chance im buying something similar but not the same. is it this one? http://www.etcetera.co.uk/products/ADS100.shtml
Old 04-23-2010, 08:40 AM
Mork_ Mork_ is offline
That is the Digidesign approved card- part number API-311 and 64 bit PCI.
FWIW, I use a Belkin F5U503, Digi approved, works a treat and is very cheap.
Pro Tools Motherboard compatibility...New computer being built qtheproducer Windows 46 03-24-2016 06:40 PM
Firewire 800 to 400 adapter - anyone tried this with success? NextofKin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-29-2009 09:55 AM
OT: PCI / FIREWIRE CARD: G4 Mac : Success skippy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-12-2006 09:38 PM
Self Built FireWire Drive unit CaptAhab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-28-2003 12:57 AM
845 motherboard success psycho Pro Tools TDM Systems (Win) 0 06-26-2003 02:55 PM
