Old 12-08-1999, 07:18 AM
tombi tombi is offline
Default QT from internal G4 ATA
Does anyone of you wizards know if I can run QT-video from my internal ATA HD while the audio plays from an external SCSI-drive attached to a SCSI-accelerator? And can I run the video on the processor power without the MiroMotion-card?
Thanks...
/T
Old 06-20-2000, 04:52 PM
Polaris Polaris is offline
Default Re: QT from internal G4 ATA
Yes. I stuffed a 36 gig AT66 drive into my G4 which is used strictly for QT Movie playback in PT and it works great. Not sure what you're asking about running pix without a MIRO or other video card. You need some sort of capture device and most require you use their compression scheme to obtain true 30fps/60field video playback. Good luck
Polaris
Old 06-20-2000, 10:48 PM
octophonic octophonic is offline
Tombi,
I am using a 20 Gig ATA just for QT playback and it works fine. Blue G3 400 MHz with an Auroa Fuse video card.
MC Pro with Internal SSD lukesytan System 5 8 05-14-2013 09:22 AM
2nd Internal HDD? dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-29-2008 09:05 PM
I've Never Had To Do This, Is It Internal? Bloux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2002 11:41 PM
Internal HD G-Dog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2000 10:03 AM
internal hd for g4? fiddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-02-2000 04:57 PM
