Old 11-06-2010, 07:40 AM
372cat 372cat is offline
Default HD Native and Apogee
Might I expect no tradeoff in performance between my Apogee 200 with X-firewire cards in PT LE v9 versus Pro Tools|HD Native v9, or is there a clear winner? What it boils down to is: Do I keep what I've already spent money on and get the Complete Music Production Toolkit upgrade, or would I realize substantial benefits by going with the HD Native corecard?
Thanks,
Jerry
jerry
www.proguitartracks.com
Old 11-06-2010, 08:49 AM
ddjembe mutombo ddjembe mutombo is offline
Default Re: HD Native and Apogee
I was thinking the same thing. The Avid native PCIe card is essentially the same concept Apogee symphony PCIe. Except for the avid card was viewed as a way to operate PT HD in native when it was initially announced.
My assumption is that the Avid card will work more efficiently with PT 9, but I would like to hear from an Avid rep.
Old 11-06-2010, 09:13 AM
TOM@METRO's Avatar
With the Avid card you will need an Avid I/O.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-06-2010, 09:16 AM
wizprodux wizprodux is offline
The new Avid converters sound better and,
it's meant to work seamlessly with PTHD Native
Old 11-06-2010, 10:53 AM
nst7 nst7 is offline
You can use the Rosetta with the HD Native card if you get the Apogee X-HD card.
Feature wise, it would be pretty much the same as the other way, but with the added stability of PCI, the option for more I/O, and the 64 bit floating point mix engine, which no ones gotten to test yet, because HD Native is just now shipping.
From what I've heard about them though, the new Avid HD interfaces sound better than the Rosettas and the AD16x series.
Old 11-06-2010, 11:27 AM
Violet Violet is offline
Are you sure about this Tom?
I spoke to Apogee tech support, who informed me that the new Apogee I/O will be compatible with AVID HD cards. This was before the Native card was released though. About 2 weeks prior actually.
PT 9.0.3
Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's
....and a couple other toys.
Old 11-06-2010, 01:37 PM
RobertDorn RobertDorn is offline
Anyone here who got a chance to check out both the new Symphony I/O and the new Avid HD I/O?
Quite curious how the conversion quality of these interfaces compare.
Thinking of getting HD Native. But also now with ProTools 9, entire apogee symhpony system (Io+ pci-e card) might also be an option. Still HD native will probably be more rocksteady regarding latency, or not?
Old 11-06-2010, 06:19 PM
Tragic Dog Tragic Dog is offline
any apogee interface that can support the X-HD card or the HD card for the Symphony IO will work with PT 9|HD as long as you have the PCIe card installed in your machine. All the apogee cards do is emulate a 192, and the old 192s will work fine with PT 9|HD.
Jon Lillie
Behind the Light Productions
PT 10-CPTK-Motu Traveler v1
Mac Pro 2x2.8GHz Quad-Core, 14gigs of ram
Macbook Pro w/Retina Display, 2.3Ghz i7, 16gigs of ram
Old 11-06-2010, 06:26 PM
carlone carlone is offline
Check out the Pro audio Review magazines review of the Avid interfaces. Extremely positive reviews.
Also, remember that the apogee I/O's don't always auto switch sample rates. So make sure you manually switch if you work with sessions that could be 44.1 or 48 or higher.
[IMG] code is Off
Apogee Duet 2 for monitoring new HD Native setup IVcrane Pro Tools HDX & HD Native Systems (Mac) 4 03-14-2014 09:13 AM
avid hd native pro tools 10 + apogee ensemble sergiostereo Pro Tools HDX & HD Native Systems (Mac) 1 07-31-2013 01:34 PM
hd native + apogee symphony? ericlees Pro Tools HDX & HD Native Systems (Mac) 12 01-23-2013 03:38 PM
HD Native/omni vs Apogee symphony Matchless Gift Pro Tools HDX & HD Native Systems (Mac) 10 04-16-2011 07:41 AM
HD Native and Apogee 372cat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-04-2010 01:09 PM
