Old 01-25-2021, 04:29 AM
jeff j jeff j is offline
Default Kurzweil SpP-6 in Pro Tools 10
I am having trouble having Pro Tools 10 to recognize the Kurzweil SP-6. If anyone has a link for step by step directions, would be appreciated. I have found none on any sites so far...Have not found any reference to drivers needed,.. I have tried to access Kurzweil's resource page to no avail, I have also contacted them, waiting to hear back... etc. Thanks!
Old 01-25-2021, 08:15 AM
Default Re: Kurzweil SpP-6 in Pro Tools 10
Things to check:
1-how is the keyboard connected to the computer(USB or midi cables)?
2-have you done the setup in Pro Tools? You don't mention if you are on Windows or Mac(see why information is important). For Windows users, open Setup>Mid>MidiStudio. In that window you need to create a new "instrument". Name it whatever makes sense for you(brand and model are not required). The crucial setting is the Input path(where PT will "look for" incoming midi data). With a USB connection its probably something like "Kurzweil SP6 USB[Emulated]". With midi cables, it would be whatever those midi cables connect to(such as a USB-Midi interface, or the midi ports on your audio interface, which you also never mentioned)
3-The Output path will also need to be set if you want to trigger sounds from the keyboard(of course, that will also require connecting the audio outputs of the keyboard to your interface).
Old 01-25-2021, 09:57 AM
I am using MacBook Pro Mid 2012, Focusrite Scarlett 2i4, Yamaha HS80M monitors, Kurzweil SP-6 Synth, Pro Tools 10
Kurzweil PC3X with Pro Tools 9 Ambient Dreamer Windows 4 02-24-2019 12:22 PM
Kurzweil Rumour? tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2004 10:29 PM
Kurzweil KSP 8 songman Tips & Tricks 7 10-12-2003 11:01 AM
kurzweil ksp8 all you need? sinew1958 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2003 12:33 AM
Kurzweil,Kurzweil......2500.... petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-06-2000 08:24 PM
