Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-16-2000, 10:10 AM
Loopman Loopman is offline
Default Help!!! Midi Does Not work
I'm using PT LE With Audio media 3 On a G4 350 & I cant get midi to work.When I first Got LE 50 It Worked. everything is hooked up right
What can I do ?
Old 05-17-2000, 12:15 AM
CHRIS AIKEN CHRIS AIKEN is offline
Default Re: Help!!! Midi Does Not work
what part exactly is not working?check your midi communication with test studio in oms.if your interface is communicating with oms check your midi input devices.
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 05-17-2000, 09:48 AM
DigiTechSupt's Avatar
Loopman
Please specify what is and is not working
in your setup. Keyboards, modules,
MIDI interface, OMS setup to start.
Also you call in to tech support at
650-842-6699 for your under warranty
system and the techs can assist you with your
MIDI problems.
Mj
Avid Audio Tech Support
Support FAQ
MIDI doesn't work!!?!!! meyoik MIDI 1 04-25-2010 02:30 PM
digi 001 midi ports + OMS . Cant get midi to work voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2006 12:32 PM
can't get the midi to work!!! lale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-07-2005 01:34 PM
Getting midi to work! optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-15-2003 02:40 PM
Help: Can't get the midi to work!? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-28-2001 04:29 PM
