Old 04-26-2001, 08:47 AM
cmrahm cmrahm is offline
Default Digi 001 on a network setup?
Can anyone tell me if Pro Tools LE will work as part of a network? I have asked my local tech shops and have been told yes and no. My problem, I have one setup with a 001 in my home studio for recording and another with Tool Box XP in my home office. I want to be able to record on one setup and mix/edit on the other but I don't want to deal with burning session files to disk and transfer them via CDR. It would be easier to add the 001 system to the existing network. Can this be done? Please help. as of now I'm quickly running out of CDRWs.
Chris
Old 04-26-2001, 10:06 AM
Mark_Knecht Mark_Knecht is offline
Default Re: Digi 001 on a network setup?
Chris,
If by 'network' you mean ethernet (my assumption) then I've got networking enabled in my machine and am having no problems if I do one important thing - UNPLUG MY ETHERNET CABLE WHEN RECORDING! This simple operation allowed my to get from a lot of PCI and interrupt problems to very few.
Obviously you won't be doing a lot of netwoking while doing the work, so you can plug things back in when you need to move files or do other things.
Go for it.
Mark
Old 04-26-2001, 05:05 PM
Sound_Underground Sound_Underground is offline
I run my system on a network and I just toggle the enable/disable on the network card in my Windows system device manager. There are no interrupts once it is disabled.
Old 04-27-2001, 06:08 AM
mlemos mlemos is offline
I also disable my ethernet card when I use PTLE. I don't even have to restart when I disable or enable the card to get an IP address.
If you unplug the cable you are still using the same system resources that you were using when the cable was plugged in.
Marc
new digi 02 setup, which os, etc 68topls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2010 03:25 PM
digi, why enabling my nvidia network controller is stopping protools 8 in it's tracks music project 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-10-2009 01:37 AM
Digi 001 Mac Setup DorianMode001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-26-2005 09:59 AM
DIGI, Rocket Network going out of business, what's it mean for Digistudio? amiller Pro Tools TDM Systems (Mac) 40 04-06-2003 01:31 PM
Digi 001 Setup Help rj333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-24-2003 06:15 PM
