Old 01-04-2024, 03:12 PM
Thousand Words Thousand Words is offline
Default Eucon command to render targeted Audiosuite?
Is there a Eucon command to render targeted Audiosuite plugin?
I realize there are 3rd party solutions like soundlflow.
Obv, they need a host of additional features to justify the costs they charge.
Eucon has been great right from when it was first released, but now is becoming a game changer in my workflow, and eliminating need for so many of those 3rd party apps.
Being able to render a plug that lives open on my DAW while editing and or mixing would be really helpful.
thanks
Old 01-05-2024, 08:04 AM
Default Re: Eucon command to render targeted Audiosuite?
You might consider this little utility: https://www.jackmeadows.co.uk/render-friend.html
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-05-2024, 08:10 AM
thanks will check that out
Old 01-07-2024, 08:47 AM
Tried to reach out to the guy that is selling that app with a couple questions, and only got crickets.
3rd party work arounds...
Any Eucon command??
Old 01-07-2024, 09:42 AM
its2loud its2loud is offline
There is no Eucon Command unless you make one with Keyboard Maestro and assign the keyboard shortcut to a Eucon softkey. I have mine setup to be F19 for Render of an open audio suite window. I only have it working with only one plugin window open at a time. If you have more than one window open it would just take some more finessing to get keyboard maestro or apple scripts to work.
Old 01-15-2024, 11:41 AM
In case anyone is looking for similar. I found a great thread to open render audiosuites, and then a separate one to close the window. All with apple scripts. Took a few minutes, but not very long and it is running.
search for the below.
Avid Pro Audio Community > Pro Tools Software > macOS
Soft Keys/Macros for rendering Audio Suite
Old 01-18-2024, 12:50 PM
Felix Rost Felix Rost is offline
I have been working on a helper app that can do this called KeyScope.
It can speed up things a lot, as you can have hotkeys to targeted or named AudioSuite plugins and also fix the processing settings or preset if you like. You can also assign single hotkeys while still using that key in text fields. Reaction speed is faster than the Applescript solutions.
The app is currently in beta and free.
Ah, of course you'd have to set up those hotkeys as key press in Eucon.
http://felixrost.de
Old 03-20-2024, 04:43 PM
thanks.
I'm going to check that out.
I've been using soft keys on ipads, and it's pretty good.
Old 03-21-2024, 04:04 AM
marsian marsian is offline
Hi Felix,
great! I will try Key Scope.
Do you use PT scripting SDK? Have you planned an official release?
Best
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 03-22-2024, 05:45 AM
KeyScope uses macOS Accessibility (but not via AppleScript, which is slow).
There's currently no release planned, I'm waiting for more user feedback and also don't have the time at the moment. But it can be used as is and works well for me.
I haven't found a real use for the Pro Tools Scripting SDK. To be honest, it looks pretty unfinished to me.
http://felixrost.de
Audiosuite won't render PT11 TLK Tom Pro Tools 11 10 11-04-2017 01:13 PM
Audiosuite Render key shortcut :Rob: Pro Tools 10 18 07-24-2017 01:22 PM
Audiosuite problem no render pt 11.3 sares Pro Tools 11 1 02-02-2015 02:40 PM
Render with audiosuite critictalk Getting Started 5 05-26-2014 04:16 PM
AudioSuite Render Behavior Peter Baird Post - Surround - Video 4 11-22-2012 12:56 AM
