Old 12-02-2023, 12:30 PM
samplaire's Avatar
samplaire samplaire is offline
Default 0dBFS - really?
It’s theoretical but also a practical question,well, a set of questions.
I mix 2 tracks and sometimes the sum (on a master track/fader) shows the signal goes beyond 0dBFS. Ok. So when you bounce the material the resulting file should show 0dBFS (when imported back to PT or any other audio editor or DAW) because there is nothing above 0dBFS - it’s a digital domain. Right?
Ok, to avoid going beyond 0 I put, say, L2 or L3 without any threshold or celing slider movement. And the result seems to be achieved - no red leds on the master meter. Right?
Of course there is this ‚between’ state which can be missed during the sampling process so the peak can go beyond 0. A little bit, right?
Then I put, say, WLM plus which features True Peak limiter. When I enable it right after the L2/L3 it tames the signal sometimes by 3-4dB! How come?
The same is when I apply the WLM To limiter on an imported wav from my first example. How come?
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 12-02-2023, 12:56 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 0dBFS - really?
Exceeding 0 dBFS on a fixed point mixer results in nasty and very audible distortion. Exceeding 0 dBFS on a floating point mixer just starts smearing the sounf´d, which you would first notice on lack of detail on reverb tails.
Janne
Old 12-02-2023, 01:57 PM
samplaire's Avatar
I remember the time when recording to DAT and I know the glitches ;-). Thanks for your input but this doesn’t answer my question, however
Old 12-02-2023, 01:58 PM
JFreak's Avatar
You may be talking about intersample peaking, which is why many albums are mastered to -1 dBFS and radio edits to -2 dBFS.
Janne
Old 12-02-2023, 02:16 PM
samplaire's Avatar
Yes! I meant it! But I thought it can be something max 1dB. I also master radio commercials to -1. But considering my observations with the 4-5dB it seems this is something else…
Old 12-02-2023, 02:35 PM
JFreak's Avatar
Loudness wars started in 1940's, ever since everyone has tried to fit more than possible into the medium in use.
Bass heavy stuff can have +6dB intersample peaks. Mastering to radio, tv, cd, streaming, etc. has become art in itself.
Just be on the safe side and adjust your limiter output to minus enough.
Janne
Old 12-02-2023, 04:05 PM
BScout BScout is offline
Intersample peaks can exceed 1dB.
But more likely your issue is metering ballistics.
ProTools’ meters aren’t bit measurements. (Though there are a lot of options in preferences for those meters)
Old 12-02-2023, 05:00 PM
First question would be what do you/the plugin have all the “True Peak Max” etc. set to? Then have you used the trim button to adjust the make up/down gain? Or just manually adjust the gain?
Old 12-02-2023, 05:56 PM
Sardi Sardi is offline
TP limiting is not allowing any peaks to go over 0dbFS. True peaks can indeed be as much as 3-4dB depending on the source. This is not uncommon.
Also, why are you bouncing out radio promos at -1dbFS? This is going to be turned down immediately to whatever playback level the station is set to, these days probably -23LUFS. To get anywhere near that ballpark, you’d be down near the -10 to -12dbFS peak readings, depending on how squashed the mix is. Have you been asked to deliver this hot?
Old 12-03-2023, 11:59 AM
samplaire's Avatar
Thanks for your answers! My questions are rather provocative, they are not moaning, I’m just interested
-23LUFS is for TV here in Poland, radio stations take 0dBFS spots. I’ve been working at a radio station and most of them have a multitool called Orban at the end so everything is pressed to the same level (compression, eq, stereo image) . This way Presley and the newest EDM hits have the same level. I even remember I had to master jingles (sung ones) the way music was 3db lower than vocals not to have the vocals crushed. Orban settings are very aggressive. I once tried to play a song with a fade at the end to the end and it pulled the level up like it was still at its loudest. I hope you get what I mean ;-)
PT mixer headroom severely reduced to 20dB over 0dBFS. Bug? Farhoof Pro Tools 61 11-09-2023 01:33 PM
Audio clip Waveform height to show 0dBFS correctly? Firechild Pro Tools 2020 8 01-16-2021 05:29 PM
0dBfs calibration/metering confusion, need help please Loudyman General Discussion 9 04-27-2013 02:18 PM
Mbox used with other apps shows 0dBFS noise on input nagra4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2007 10:36 PM
Peaking above 0dBFS rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-16-2005 01:06 PM
