Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 03-25-2021, 12:04 PM
dr sound's Avatar
dr sound dr sound is offline
Default NEW Avid SYNC X
Avid just released a new "Sync X"
https://westlakepro.com/avid-pro-too...n+Synchronizer
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 03-25-2021, 03:00 PM
LukeHoward LukeHoward is offline
Default Re: NEW Avid SYNC X
Originally Posted by dr sound View Post
Looks good! Surprised there’s no support for PTP for AES67, Dante, SMPTE 2110, AVB etc but perhaps the mainstream market isn’t quite there yet.
https://lukehoward.com/
Old 03-27-2021, 10:06 AM
bzone bzone is offline
Have been using the Trinity and 10M for years. Haven’t read through everything yet. Has anyone worked with it yet? Clocking comparisons, very interesting set up? As stated supported connection’s ?
Old 03-27-2021, 11:03 PM
I doubt it’s going to make a difference sonically with modern interfaces but certainly improves things workflow wise, particularly with the MTRX not supporting Loop Sync.
Old 04-02-2021, 01:29 AM
K.I. K.I. is offline
Hi.
I was using 10M. You can enter 10M directly. it's the best. The sound changes.
It is good that the word out of SYN X is output even when PT is not started. MTRX always synchronizes.
Old 04-02-2021, 06:49 AM
lucienpalmer lucienpalmer is offline
I was just looking at that, too.
So without directly being the master for Dante clock, would we slave the MTRX to the SyncX and make the MTRX the Dante clock master?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 04-02-2021, 12:55 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Yes, you'd connect Word Clock out from Sync X to Word Clock In on MTRX. Clock source for MTRX would be Word Clock. And, Dante clock master would be MTRX.
If MTRX wasn't used, then you'd connect Word Clock out from Sync X to Word Clock in on a Dante device. Then, that Dante device would become the Dante clock master.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 04-11-2021, 05:48 PM
Well picked one up. It does everything it is advertised to do. Would be nice to have a pull down menu to change clock frequency inside the session. Even worked clocked to different frequency settings when opening a singular Logic session for playback, no editing. Don’t know if it was supposed to be able to do that and act like an actual clock.
Old 04-12-2021, 06:50 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Can the built in video ref generator automatically switch to the video framerate of the video file in the Protools session or do we need to manually switch videoref framerates each time we switch from a 24/25fps session?
I know it has auto sensing incoming ref signals, but I don't see any auto switching ref generator according to timeline video or something like that.
Old 04-12-2021, 07:18 AM
Hello,
You can change the pull up/down settings in the bottom right corner of the Session Setup window.
Regarding behavior with Logic, what was the Logic project sample rate? And what was the clock source and sample rate for Sync X? Was the CLOCK REF indicator on the front of Sync X solid green? If there was a sample rate mismatch between Logic and Sync X, then Sync X may have remained locked but Logic would play back at the wrong speed/pitch.
Kyle Splittgerber
Berkeley, CA
Avid Sync HD, $800 lucienpalmer Buy & Sell 1 08-27-2019 07:27 PM
Avid Sync I\O Raemond Cook Getting Started 12 02-21-2019 02:57 AM
Avid Sync IO HDXSound Pro Tools 12 20 05-30-2017 04:53 AM
AVID Sync HD won't generate 23.976 LTC jim33 Pro Tools TDM Systems (Mac) 1 01-20-2012 10:20 AM
AVID / PT sync - Help Iamrod Pro Tools TDM Systems (Mac) 3 05-17-2001 01:33 PM
