Old 04-14-2017, 01:09 AM
lloydsound123 lloydsound123 is offline
Default Smpte
I'm trying to sync PT with incoming timecode. I can see the timecode in my session setup but somehow I can't get PT to follow the timecode. My setup is a Profire 2626 & M-audio Midisport 8x8S. The Midisport is receiving the incoming timecode from a timecode generator.
Any ideas how I can get PT to lock/follow incoming timecode?
Old 04-14-2017, 02:44 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Smpte
Did you enable the Online button in the transport window?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-14-2017, 03:26 AM
Default Re: Smpte
I managed to get it to work. It was a frame rate issue that I had to change in the session setup. It had to match the number the frame rate from the timecode generator
Old 04-14-2017, 03:35 AM
Drew Mazurek's Avatar
Default Re: Smpte
Understand that what you're doing is "lock and release" sync, and it will drift over time since PT isn't synced to the external source's clock. How much? Who knows, it depends on the difference in the two clocks. This is all in the other thread you posted in and linked threads.
www.drewmazurek.com
MTC-To-SMPTE/SMPTE-To-MTC Interface - What do YOU use? Nawlins Post - Surround - Video 5 03-20-2008 02:55 PM
SMPTE with PT LE ***BBOY*** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-20-2005 09:18 PM
OT:SMPTE, LTC, MTC.... 1150Post Post - Surround - Video 8 11-14-2003 11:44 PM
I have SMPTE in LE Mark Reis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 36 05-02-2002 10:03 AM
SMPTE...again arb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-23-2002 12:34 AM
