34" Wide Screen / 2009 MacPro Problems
So I recently upgraded my studio monitor, previously I had a 29 inch widescreen monitor, I now have a 34 inch widescreen monitor. My stock video card with my 2009 Mac Pro, had no problems achieving max resolution on the 29 inch widescreen, but simply will not do it on the 34 inch widescreen.
The best I'm able to get is 1080P with that monitor using my current stock video card. I've tried every adapter known to man, and none of them have worked properly. I just don't understand why it works fine on a 29 inch widescreen, yet won't with a 34 inch widescreen? This is the monitor I'm trying to make it work with. http://www.lg.com/us/monitors/lg-34U...rawide-monitor All I'm trying to get the monitor to display is its max resolution of 2560/1080, according to the specs of the video card, it should be capable of doing that, but for some reason I can't get it there. I end up with 1080P, stretched, so I'm not able to get as much of the ProTools screen as I should be able to get the same way I'm able to get with my LG 29 inch widescreen. If I need to put a different video card in my computer I'm fine with that, however I don't want to spend a Ton of money on it. Any solutions, possibly video card recommendations?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Re: 34" Wide Screen / 2009 MacPro Problems
I did some quick Googling and saw some people mentioning a similar problem when using the HDMI ports on their Macs. They resolved the issue by using the displayport instead.
I have a 3840 x 2160 4K monitor that works on an early 2015 MacBook Pro. It will do 60Hz on the thundberbolt port, but only 30 Hz on the HDMI port. I think that 2015 MacBook Pro has an HDMI 1.4 port. You could likely get a different monitor which will work with your card (Mac video cards are kind of pricey). I have a 2010 Mac Pro with the ATI 5870. Even though it has two Mini Display ports and a DVI, only the DVI port will drive the 3860 monitor (and only at 30Hz). The display ports will drive a 2560 x 1080 monitor (which I pulled off a PC to test) and will also drive an Apple Cinema type monitor (2560 x 1440). I bought a QVS active converter mini DP to HDMI and it is driving a 2560 x 1440 monitor okay now. A similar Accel active DP to HDMI converter is also available.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon Last edited by panamajack; 04-21-2017 at 03:09 PM. |
I also have an LG widescreen.
Mine wouldn't work HDMI until I downloaded this little piece of shareware called SwitchResX and now it's awesome. http://www.madrau.com/ It took a couple restarts and stuff, but I LOVE the widescreen. I got mine on Black Friday. GC didn't have anything good so I went into Best Buy, where I never shop. They were blowing them out - and they even had a ProTools session on the demo video. Best thing I ever did for mixing and editing.
Apple M1 Mac Studio (base model) ProTools Carbon w/SSL XLogic MADI-AX Instagram: https://www.instagram.com/sparkletune/ |
2009 MacPro 4.1 for HD Native or HDX | Barry Johns | Pro Tools HDX & HD Native Systems (Mac) | 4 | 07-21-2015 08:27 PM |
2010 iMac 27" i7 quad VS 2009 MacPro 2.66 Xeon | sweetness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-27-2010 11:01 PM |
.mov not wide screen when imported | dubaifox | Post - Surround - Video | 3 | 10-07-2007 06:58 AM |
19" Wide Screen | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-19-2006 02:21 PM |
Way Off Topic Wide Screen TVs For Recomendations | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-05-2004 03:28 AM |
