Old 04-11-2017, 02:14 PM
kennethtyler kennethtyler is offline
Default Reverb busses outside of Low-Latency mode in PT12
Hello friends! I'm new here and hoping some qualified professionals can assist me with a problem I'm having. I'll try to explain my set-up and signal chain first.
When tracking vocals, sometimes I try to create a little bit of the finished result in my vocalists ears. Typically, I don't like doing this because it can cause pitchy performances - but with other people they are able to perform better with effects added.
I have a Neumann TLM103 going into the first channel of my UA 4-710d. I'm inserting my EL8 Distressor and pushing that signal to my Apollo Twin. At this point, I'm adding a Pultec EQ and an LA2A into the insert path in the UAD Console. After this, it's going directly into Pro Tools with no effects inserted in PT.
At this point, everything sounds excellent. However, I can't seem to add a reverb without turning Low Latency off. When I do this, the vocal sounds like a double. Almost like I turned on a 0.20ms slapback delay. I'm confident this has something to do with latency, and I'm wondering what the workaround is.
Any thoughts on how I can add reverb without this weird doubling sound?
Thanks in advance!
Old 04-11-2017, 02:55 PM
john1192 john1192 is offline
Default Re: Reverb busses outside of Low-Latency mode in PT12
do you have a mix control on your verb ... turn it to Full Wet !!! maybe ...
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-11-2017, 02:57 PM
I should have been clearer, but prior to any reverb I have a weird vocal latency sound. Like it has been doubled, or sounds phased. This happen immediately after I turn off low-latency.
This being said, you are correct that a reverb without full 100% wet would imitate a similar sound. But that's not the case here, as I'm not able to solve the doubling sound via monitoring vocals.
Old 04-11-2017, 02:58 PM
Drew Mazurek's Avatar
Thanks in advance!
With LLM off, you're subject the twice the buffer of latency plus any plugin induced latency. You'll need to set the buffer to 64 or maybe even 32 if it's available. And you can't have high latency plugs on Auxes or Master Faders.
www.drewmazurek.com
Old 04-11-2017, 03:02 PM
Ben Jenssen's Avatar
I think maybe the delay comes from the inserted reverb is not 100% wet?
I'd make a aux track, input set to the mic, and the reverb plugin set to 100% wet. (It will have the 20ms, as a kind of reverb pre-delay.)
Oh, and welcome to the DUC.
Old 04-11-2017, 03:31 PM
Very helpful Drew and Ben! Thanks for the insight and the warm welcome. I will try this and report back on results. Thanks again!
Old 04-11-2017, 04:03 PM
Of course you could make a reverb send in Console and leave PT in LLM. And also have a verb setup in PT. During pre roll and post roll, your verb in PT should still be active, and during the punch the Console verb would make the singer comfortable. Try it.
www.drewmazurek.com
Old 04-11-2017, 08:21 PM
I track everything at the 64 buffer and have not used LLM in years. Now I also often track 2 tracks for vocals, but mine are usually 2 mics. Whenever I do this, 1 of the 2 tracks stays muted(the producer can decide later on which mic is preferred). My vocal reverb is always on a stereo AUX track, fed by a send. Headphones are fed by sends on all tracks(I fill a bank of 5 sends out to 5 separate mixes for players). Reverbs are always set 100% wet
Old 04-11-2017, 08:55 PM
cwsand's Avatar
cwsand cwsand is offline
Prior to any reverb I have a weird vocal latency sound. Like it has been doubled, or sounds phased..
So for whatever reason you're hearing 2 live sources of your vocalist where you need to hear just one. So try to figure out where both signals are coming from and mute one. It could be that you're hearing one signal from your console and the other from the record-enabled track - if that's the case, then check the "Mute Record-Armed Tracks while Stopped" option in Preferences (assuming you have HD). That way you'll hear only one live source while recording, but will still be able to hear playback of the recorded audio.
I don't currently use a console, but I do basically the same thing using an Aux track with the same source as the recorded track. This is also nice in that I can hear the singer if they say something to me during playback. I also use reverb at 100% wet on an Aux track fed by sends so that I can adjust the reverb level fed to the vocalist's mix independent from my control room mix.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-12-2017, 01:12 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Yes. If you're running vanilla, kill input monitoring on your vocal track in PT so you can hear only the direct monitored signal from your interface.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
PT12 Track Output Busses Changing JamesDrake Pro Tools 12 1 12-08-2015 04:11 PM
What busses do you use for reverb tokolosh Post - Surround - Video 3 09-22-2010 06:01 AM
Tracking Vocals with Reverb in Low Latency Mode? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-02-2010 05:36 PM
TRACKING w/ REVERB PLUGIN in LOW LATENCY MODE? minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-10-2005 01:27 PM
Reverb on rec enabled tracks with low latency monitoring mode mixaudio Tips & Tricks 0 06-16-2001 08:09 AM
