Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 03-30-2017, 04:13 PM
Le Mec Le Mec is offline
Default (HELP) Firewire card with Digi 003
I recently purchased a used AVID Digi 003 Console to use with my PC (Win7 64, Gigabyte X79-UD3 mobo, Intel i7-3820, 16 Gb ram).
I know must get a PCIe Firewire Card but i would like any suggestions/feedback regarding the following options (trying to get a friendly budget card);
Startech PEX1394A2V 2 Port 1394a PCI Express FireWire Card - PCIe FireWire Adapter
SIIG DP FireWire 2-Port PCIe NN-E20012-S2 Two-port FireWire (1394a) PCI Express x1 card
SIIG DP FireWire PCIe NN-E20022-S1
SIIG Firewire 1-Port 1394a And 2-Port 1294b PCI Desktop Interface Card F026-00R5
Will these be fully compatible with my pc and Digi 003?
Thank you in advance for any help
Old 03-31-2017, 10:41 AM
Default Re: (HELP) Firewire card with Digi 003
The 2 details that matter(If the motherboard has no firewire) are:
1-check what slots are open on the mobo so you get a card that fits(IOW, don't buy a PCI card if you only have PCIe slots)
2-make sure the card has a TI chipset(check card specs).
If in doubt, determine what slot you have and call sweetwater and tell them you need a FW card for Pro Tools as I'm sure they carry compatible cards
****WARNING****
In case you didn't know this already, NEVER "hot-patch" the firewire cable as it can(and will) fry the 003 FW chip, the card, or both(learned the expensive way here).
Last 2 cents, which driver you use can make or break function. Avid recommends using the Legacy driver(and do try it). For me(with 003) it never worked. On my rig, using the TI Compliant driver worked dandy
Old 03-31-2017, 11:05 AM
YYR123's Avatar
YYR123 YYR123 is offline
This worked for me with a 003r unit and Win7.
It's cheap too, $40 shipped priority US.
Siig FW PCIE card
http://duc.avid.com/showthread.php?t=387280
Daniel
What FireWire 400 card do I need for digi 02? georgeearth FireWire & USB Audio Interfaces (Win) 1 07-14-2014 05:50 PM
Which FireWire Card for Digi 002 Mixer Console Interface govols1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2012 01:57 AM
Digi 002 Firewire 400speed not accepted by new Mac Pro Firewire 800speed ports AncientMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2010 09:31 PM
Issue? Laptop, Firewire 410, SIIG Firewire Express Card batchmister1 Pro Tools M-Powered (Win) 2 08-07-2009 10:37 AM
DM-24 Firewire card, 002r firewire audio I/O? Blackfish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-21-2004 11:30 AM
