Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 01-28-2015, 09:07 PM
anthoven anthoven is offline
Default 003 Rack+ host problem
Hi all,
Recently my 003 Rack+ lost its firewire connection to my PC after having worked perfectly for a number of years. I am running Windows 7, and the device appears in Device Manager and is purported to be "working correctly", though in the Playback Devices of the Windows sound configuration utility, the device is not listed. I have reinstalled all associated drivers including the Standalone driver.
While I first noticed the problem playing standalone sounds, the unit also is not recognised by ProTools. I have also replaced the firewire card in the PC in the hope that might be the problem, to no avail. The unit works correctly when connected to my Macbook Pro.
Thanks for your help!
Old 01-29-2015, 09:21 PM
Default Re: 003 Rack+ host problem
Replaced the FW card in the PC, with what? Just any FW card, or a card with the required TI chipset? That little detail can make or break using 002/003. The there's the FW card driver. On a PC, there are usually 3 resident drivers available(from within Device Manager). Avid recommends the Legacy driver, but it never worked for me on 2 different PC's. The TI Compliant driver was the one that worked for me
Old 01-30-2015, 03:02 PM
The F/W card has the Texas Instruments XIO2213AZAY chipset, which I thought was within the "qualified" list, but now I'm not so sure!
I have tried the TI driver on the F/W card with no success.
Old 01-30-2015, 05:22 PM
Switching to the legacy driver solved the problem!
Thanks so much for your help!
Old 01-31-2015, 08:59 PM
bangbangbang's Avatar
bangbangbang bangbangbang is offline
my 003r worked on a macbook but not detected on my PC win7 ?
is it due to the firewire card or driver ?
bang bang bang ! see you later
Let the hardware interface with the software
Old 02-01-2015, 07:30 AM
Most likely yes. Try all 3 drivers before you replace the card.
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
003 rack Host light blinking - HELP! rockwell81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2010 07:53 PM
003 rack host light blinks teleric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-26-2009 02:20 PM
Problem with Pro Tools as Rewire Host for Reason 4 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2007 03:56 PM
host A=Protools,host B=adobe premiere:How to sync? seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2005 11:33 PM
