Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 03-24-2014, 12:04 PM
ksilver117 ksilver117 is offline
Default "Hardware Not Found."
Hi guys. I've had my MBox and Pro Tools Express for a month or so now, and other than some minor issues in the beginning, it's worked perfectly. I recently had to move my desktop computer to a different area of the room and back again later on, requiring me to unplug the MBox, although the iLok stayed in place. Since that move, Pro Tools has refused to open fully, only displaying this message:
I've tried moving it to new USB ports, and no matter which one it is in, this message stays the same. Windows can detect it, the MBox itself is functional (Lights are on, and the buttons can be pressed to activate phantom power or mono, etc) and the iLok seems to be just fine. Has anyone experienced this before?
Windows 7 Pro, 64-bit SP1
Intel Core i7 3770K @3.50GHZ
16GB Dual Channel DDR3 RAM
ASUS P8Z77-V Motherboard
EVGA Nvidia GeForce GTX 660
Hard Drives:
111GB Samsung SSD 840 Series
2794GB Seagate
3726GB Seagate
2794GB Seagate External USB
Old 03-24-2014, 12:43 PM
Craig F Craig F is offline
Default Re: "Hardware Not Found."
Have you tried holding down the N key when launching Pro Tools to reselect the mBox (may need to make it internal first)
Thank you,
Craig
Old 03-24-2014, 12:46 PM
I just did, and it made no difference in the way it launched. It loaded up partially, then couldn't find the hardware and closed again.
Hard Drives:
2794GB Seagate
3726GB Seagate
Old 03-25-2014, 06:27 AM
JoelG's Avatar
JoelG JoelG is offline
Is the device showing properly in Device Manager? What driver version are you using?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-25-2014, 06:43 PM
It was showing up properly, and I had to use an older driver. I have been unable to install the new drivers without my computer blue screening... which may be another problem.
I decided to just uninstall and then reinstall the driver, which made it instantly start working again, thankfully. Thank you guys for the suggestions, and I certainly wouldn't say no to any about updating the driver to the current version without crashes.
Hard Drives:
2794GB Seagate
3726GB Seagate
Pro Tools 10 standalone and "hardware not found" Windcruiser Windows 3 11-17-2012 01:56 AM
"hardware not found"...power light solid. cjdude macOS 16 05-28-2012 01:05 PM
Mbox Mini Lights up but "hardware not found" gramtsupak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-05-2011 09:07 PM
Mbox mini installation problem - "Hardware Not Found" tinsoldierman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-18-2010 03:06 AM
"Digi Hardware not found" mesage boynigel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-09-2010 04:33 PM
