Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 07-14-2013, 03:31 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: 003 Rack+ Front DI Jack
Yeah I would do the ADA 8000 on the budget and the focus right Octo pre for the nice one
Daniel
Old 07-15-2013, 04:39 AM
SKI's Avatar
SKI SKI is offline
I'm a heavy advocate of the original A2D.
The original model came outta the right price with the right sound.
Once they did the tweak and price change it changed it to a good deal not a great deal like it was at first.
The key is to do the best within your budget while still meeting your needs.
The OP has the Saffire so he has options already available which is a good thing.
URBAN MUSIC-
(Hip Hop and R&B)
Old 07-15-2013, 09:03 PM
Melodic Wave Melodic Wave is offline
I really like my Saffire Pro 40, it seems to work well with my 003+ Rack, and if the 003 rack went down I would simply take the FW out of the 003 and into the Saffire until the repairs were made, the Saffire works great as an interface as well, but only @ 44.1 for some reason. But seeing that cd players can only play @ 44.1 then who cares anyway.
Old 07-15-2013, 10:20 PM
YYR123's Avatar
What ????
Do you have Sapphire mix control software installed on your computer you should
Change sample rate on that
Daniel
Old 07-16-2013, 03:41 PM
Originally Posted by YYR123 View Post
What ????
Yeah, tried that already, but I can't even get a session started if the sample rate is above 44.1
The Mix Control seems to work fine as I can select and save, but no luck @ 48 or higher.
Any suggestions?
  #16
Old 07-16-2013, 06:17 PM
YYR123's Avatar
So if your focus right is your main interface then start mix control set it for 96K then start ProTools holddown the N key select the Sapphire Pro 40 and It should let you start a new session at 96k
Obviously once you select 9 6K 32-bit etc. etc.
Daniel
  #17
Old 07-16-2013, 07:00 PM
Thanks, I'll try that and see what happens.
Digi 002 Rack Busted Headphone Jack digijohn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-28-2011 01:07 AM
iMac bypasses Rack 003 and goes to internal mic and headphone jack gcharles macOS 2 01-26-2011 10:29 AM
Jack Input on Rack 003 as a DI Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-20-2008 05:47 AM
MBOX2 Distortion in the front headphone jack??? Caly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-24-2006 06:49 PM
Front headphone jack on Mbox does not work MadadaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-09-2005 03:02 AM
