Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-14-2013, 10:39 AM
jryser's Avatar
jryser jryser is offline
Default Re: Mbox 3 DSP FX Broken?
I had the same issue. I ended up sending my MBox Pro back to have them fix the problem. I was under the understanding that the firmware issue was due to multiple firmware upgrades atop each other. I really do think avid should take care of this, however I was in need of my MBox Pro was willing to pay to have it fixed. They ultimately did fix that issue for free. I had another problem with one of my preamps which I did pay for.
Sent from my Pro Tools beating heart.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 05-14-2013, 02:07 PM
Dexxy's Avatar
Dexxy Dexxy is offline
I bought a new mbox before 30 days. When the update came out I was recommended by Avid did update the drivers and then picked up the firmware to 1.0.3. It's their fault I do not have the time and the ability to return the mbox and wait for repairs because I have a lot of work to do. I hope you will fix it for the next update.
Sent from my GT-N7100 using Tapatalk 2
Old 05-14-2013, 04:32 PM
CHRIS AIKEN CHRIS AIKEN is offline
I see, so obviously this is a known problem. Has avid acknowledged this problem? Is anything being done about it?
Thanks for the input.
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 05-14-2013, 04:36 PM
jryser's Avatar
Yes and yes. I don't think we have been informed en masse!
Old 05-14-2013, 04:37 PM
jryser's Avatar
And lastly, it does not appear so publicly.
  #16
Old 05-14-2013, 06:07 PM
guatamas guatamas is offline
A lot of people are having this issue.
  #17
Old 05-14-2013, 06:13 PM
Dexxy's Avatar
I saw it and what in the end no solutions???? In addition to send them to me improve my mbox .. a device I can not stay without mbox I have a lot of work and it was not even a month since I bought it ... Can not be solved with some new firmware updates or to downgrade ..???
  #18
Old 05-14-2013, 06:14 PM
Default Re: "Tuner" and internal "DSP" doesn't work on Mbox Pro (3G)
Whether its in standalone or being used by pro tools the issue is there and as Pinball Wizard said, I also believe this is a firmware issue
A google search shows other posts.
  #19
Old 05-14-2013, 06:19 PM
In the link the first post says Avid is aware of the issue and are working on it. If you can't send it in for repair then all you can do is wait until Avid finds a solution.
  #20
Old 05-14-2013, 06:29 PM
Dexxy's Avatar
ok sorry I did not see it. Thanks for your help ... hopefully soon update the solution of the problem.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
3tuner" and internal "DSP" doesn't work on Mbox Pro (3G) luckydjacks Windows 0 12-31-2012 04:40 AM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
