PT10 interop with PT9/8/7 -- Can PT10 force .ptf compatible audio?
I'm thinking about PT10 interop with PT9/8/7. (Don't we all work with a few people who are still on 7?)
So there's a new .ptx session file format, and the option to "save backwards" to .ptf. But when it comes to the audio media, since we now have support for polyphonic and mixed bit-rate audio, audio files compatibility is not a given. I'm sure you can "save-in" and recopy all the media, but let's say you want to avoid the duplication and accompanying hassles. Is there a way to force PT10 to conform to the old way (monophonic files, session-based bit rate) for all imported? Can anyone with PT10 confirm? -jeremiah |
Re: PT10 interop with PT9/8/7 -- Can PT10 force .ptf compatible audio?
in its default state, PT10 behaves as PT9 as far as audio files go- in the prefs you can specify if you wish to use interleaved files....
when you export as a PT7--9 session it converts the realtime fades and clip gain goes to automation. |
Thanks Charles -
So I assume you can "save copy in" without recopying the media, and moving between 10 and 7--9 is as simple as "save copy" (and being careful how you handle the incompatible features.) -jeremiah |
speaking of interleaved files:
can you still do the same tricks to them like with split files? swap tracks via mono tracks. nudge left and right against each other via mono tracks. or are they now tied together so that you can't use all those beloved tricks of the trade? frank
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Blah blah blah....grumble grumble....woo hoo woo hoo.....dig it? |
I assume the audio files are converted to whatever the session uses as they is lifted into RAM?
I get a feeling AVID thought: What happens if we preload all audio into RAM? What is available to us then? And suddenly we have realtime fades, premixer gain, and support for different audioformats. (possibly it also opened for AS with handles) All of which are fantastic things. (Well, the gazillion fade files never bothered me much...)
Newest Pro Tools on mac & pc. |
Unfortunately, there doesn't currently seem to be any way to ONLY process the non-standard files, either in the project browser, or when doing a Save Copy conversion. You are forced to copy ALL files if there is even one "offender". I really hope Avid fixes this.
The only way to automatically cause imported files to be "legacy friendly" is to force imported files to be copied in "legacy friendly" format by doing the following -
Check the "automatically copy files on import" preference AND Check the "Convert Copied Files to Session Format" preference dc |
Thanks Danny! Thats exactly what I was hoping for. Perfect.
-j Sent from inner space |
pt 8 files compatible with pt10 | muscmp | macOS | 3 | 06-24-2013 10:22 PM |
Force PT10 to make a "Fade Files" folder when saving .ptf? | gguardia | Pro Tools 10 | 2 | 06-15-2012 12:50 PM |
11R compatible with PT10 stand alone? | billyrides | Eleven Rack | 13 | 03-13-2012 09:39 PM |
ReverbOne 1.0 (MS-134) compatible with PT10? | NewdestinyX | macOS | 5 | 01-04-2012 06:50 PM |
Duy compatible with PT10 and Lion? | lee52813 | macOS | 14 | 01-04-2012 06:53 AM |
