Old 05-25-2010, 11:16 AM
tgrfox tgrfox is offline
Default Tempo change causing midi volume to change plugin output
I'm writing a track using Battery 3 plug-in. It was generally working fine and I could set the output level with the master knob in Battery, but then I decided to change the tempo of the track and now the master knob is being controlled by the midi volume level which, at its highest setting, only gives a -6dB output when it has a range up to +12dB.
I've tried opening a backup from before I changed the tempo and it's fine but I get the same problem as soon as I change the tempo.
Any idea what's going on?
Thanks,
Tom
Old 09-09-2010, 12:00 PM
benergy benergy is offline
Default Re: Tempo change causing midi volume to change plugin output
So annoying!!! I've been having this problem ever since (I think) 7.4. Happens most often with Battery and Kontakt, no matter which version I use, but also just had it affect Xpand2 as well. Sometimes putting the midi volume on inst tracks all the way up to 127 after the tempo change fixes it, but not always. I've also had PT drop random volume automation marks (always turning the volume way down) in the middle of midi regions and had to delete those. Would LOVE a solution to this because changing the tempo should have NO effect on volume levels of insts.
Old 08-05-2011, 01:08 PM
Every come across a solution to this? Still irking me on a daily basis.
Eleven Rack doesn't change sound output when I change to a new rig Jlambton Eleven Rack 4 02-28-2011 11:51 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Very weird 888/24 MIX random output volume change chroma17 Pro Tools TDM Systems (Mac) 5 08-02-2006 11:19 AM
midi and tempo change pt III dubman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2005 03:18 PM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
