Old 04-25-2010, 03:09 AM
meyoik meyoik is offline
Default MIDI doesn't work!!?!!!
I am running Pro Tools 8 (Vista 32 bit SP1) and trying to run the "Make a beat" example on the Getting Started booklet (pg 17).
This is what I have done so far:
1. I hooked up a MIDI-Out (from a Yamaha PSR-275 keyboard) to MIDI-In in M-Box
2. I created a MIDI track.
3. With the Input Selector I chose an Xpand2 Loop.
4. Options/MIDI through selected
5. Record enable on, Record button and then press Play (to record)
6. Nothing happens....
What am I doing wrong?
Do I need to install additional drivers? Software?
Do I need to configure something?
Old 04-25-2010, 02:30 PM
tlennon tlennon is offline
Default Re: MIDI doesn't work!!?!!!
Make sure you check the box for Yamaha in midi devices.
Terrence Lennon
Ivory Key Productions
digi 001 midi ports + OMS . Cant get midi to work voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2006 12:32 PM
can't get the midi to work!!! lale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-07-2005 01:34 PM
Getting midi to work! optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-15-2003 02:40 PM
Help: Can't get the midi to work!? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-28-2001 04:29 PM
Help!!! Midi Does Not work Loopman General Discussion 2 05-17-2000 09:48 AM
