Old 04-22-2010, 11:00 PM
ilovemyssl ilovemyssl is offline
Default "a-z" button stops working on Edit page
This is driving me *crazy*.... I am running 8.03cs1 LE, and every hour or two the "a-z" focus button stops working on my Edit page, and i have to reboot ProTools to get it to work again.
What is up with that??
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 04-23-2010, 05:21 AM
robo6675 robo6675 is offline
Default Re: "a-z" button stops working on Edit page
Did you try pressing cmd+option 1 of the alpha-numeric side of the keyboard while in the edit window? ...just thought I'd ask the obvious first.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 04-23-2010, 05:25 AM
Bugly Bugly is offline
also,
I have noticed that when I have particular plugin windows open "keyboard focus" does not work.
close the plug window and all is cool again
hope this helps
Old 04-26-2010, 08:18 PM
Not sure what that is supposed to do but it doesn't appear to do anything on my system.
SSL 4056G
Old 04-27-2010, 01:01 AM
tamasdragon tamasdragon is offline
Some plugins "steal" the keyboard focus, many 3rd party ones do this.
The above mentioned shortcut should switch the keyboard focus on, but still, only then, if the plugin gui did not stole your keyboard.
my blog:Tamas Dragon
Old 04-27-2010, 09:00 PM
FWIW, it's definitely an issue with PT. It happens whether or not there is a plugin window open.
SSL 4056G
Old 04-05-2011, 01:30 PM
claybot claybot is offline
I found a relatively painless work around. I have had the same problem intermittently. I too believe it is not plug-in related but a PT8 bug. The only way around it I have found (besides re-opening the session, which can take a while if your session has a lot of samples to load) is reloading a window configuration. The last time this happened I had not created any window configurations, but after I found the kb focus button not working and command+option 1,2,3 would not bring it back on, I created a single window configuration, and then clicked it in the window configuration list and the kb focus buttons were on and working again.
I'm using PT8.0.4 on a Mac Pro
"Automation follows edit" button orange when turned off? mesaone Pro Tools 11 4 09-25-2013 03:57 PM
Old School Studio "work" flow chart from Tape Op's facebook page Craig F General Discussion 0 01-08-2013 07:21 PM
MBox "launch control panel" button not working again with the latest driver Zarabozo Windows 0 10-26-2012 12:01 AM
MC Mix losing "page" button functionality... JR Fountain Artist Series 1 09-28-2011 12:04 PM
Transfuser stopped working: "set the correct path on set up page" dannielexists Virtual Instruments 2 09-16-2010 05:37 PM
