Help Please pt8 mbox mini dreaded 6086 error
I have been scouring the forums and i am still having trouble getting any record or playback beyond a few seconds without the 6086 error. I have the requisite second firewire hd with a oxford 911 chipset at 7200 rpm. Also have tried on vista home sp 1 and xp pro sp 3 on a separate HD that I swap out. I know that I have a dell xps notebook duel core 1.83ghz, all drivers current. A lot of people seem to be having this issue with little resolution. I don't mean to be presumptuous but i have played with buffers, tried about 40 tweaks, tied all ports and meet all stated specs as far as all my reading suggests. I would really appreciate any help with this. I will check often l left anything out i will be glad to go into more detail. Thanks.
SiSoftware Sandra System Host Name : BOB User : Butters Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz Speed : 1.83GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, Inclusive, 64 byte line size, 2 threads sharing System Platform Compliance : Intel Centrino Mobile Technology Mainboard : Dell Inc. 0XR509 Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : AT/AT COMPATIBLE DELL - 27d80313 Total Memory : 3.00GB DDR2 Chipset 1 Model : Dell Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed : 4x 166MHz (664MHz) Total Memory : 3GB DDR2 Memory Bus Speed : 2x 332MHz (664MHz) Video System Monitor/Panel : Generic PnP Monitor Adapter : NVIDIA GeForce 8400M GS Imaging Device : Laptop Integrated Webcam Physical Storage Devices WDC WD25 00BEVS-75UST 250GB (SATA150, NCQ, 8MB Cache) : 232.89GB (C:) (D:) LaCie Hard Drive 500GB (FireWire/1394, NCQ) : 465.76GB (H:) Optiarc DVD+-RW AD-7640A (ATAPI33, 47x CD-R, 63x CD-W, 6x DVD-R, 8x DVD-W, 2MB Cache) : 7.94GB (E:) Disk : N/A (G:) Logical Storage Devices Hard Disk (D:) : 10.00GB (1.58GB, 16% Free Space) (NTFS) @ WDC WD25 00BEVS-75UST 250GB (SATA150, NCQ, 8MB Cache) OS (C:) : 220.29GB (22.76GB, 10% Free Space) (NTFS) @ WDC WD25 00BEVS-75UST 250GB (SATA150, NCQ, 8MB Cache) Pro Tools LE (E:) : 7.94GB (CDFS) @ Optiarc DVD+-RW AD-7640A (ATAPI33, 47x CD-R, 63x CD-W, 6x DVD-R, 8x DVD-W, 2MB Cache) CD-ROM/DVD (G:) : N/A @ Disk Record (H:) : 465.76GB (465.65GB, 100% Free Space) (NTFS) @ LaCie Hard Drive 500GB (FireWire/1394, NCQ) Peripherals USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2830 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2831 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2832 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2834 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2835 USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836 USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device USB Controller/Hub : Digidesign Mbox 2 Firmware Updater USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : RICOH OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard PS/2 Keyboard Mouse : Dell Touchpad Mouse : Microsoft USB Wireless Mouse (IntelliPoint) Mouse : Microsoft USB Wireless Mouse (IntelliPoint) Human Interface : HID Non-User Input Data Filter (KB 911895) Human Interface : HID Non-User Input Data Filter (KB 911895) Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Printers and Faxes Model : Microsoft XPS Document Writer Model : Journal Note Writer Model : Canon MP210 series Printer Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows Vista Home Media Center 6.00.6001 (Service Pack 1) Platform Compliance : Win32 x86 Windows Experience Index Current System : 4.1 Network Services Adapter : Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller Adapter : Dell Wireless 1490 Dual Band WLAN Mini-Card |
Re: Help Please pt8 mbox mini dreaded 6086 error
Did you switch off the network adapters?
Do you have a sd card reader in this machine? If Yes, they are usually connected via the USB port. That may cause the problem. Sometimes, if you don't have two identical RAM sticks, your Ram will not be addressed in dual mode, i. e it will be slower.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
"FireWire/1394 Controller/Hub : RICOH OHCI Compliant IEEE 1394 Host Controller"
This is NOT a Digidesign approved firewire controller. There is a workaround in the Knowledgebase, but YMMV. You need an approved firewire controller in the computer (TI chipset) as well as the approved chipset in the external enclosure. Cheers,
Well I reloaded a fresh copy of xp and it works great. I got to 36 tracks with 65+ plugs before it started to choke. works great!!!!
Glad to hear it, think about the controller if you get into any further trouble.
The Dreaded Error 6086/XP vs. Vista | smelin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-18-2010 09:29 AM |
6086 error on XP, LE8, MBox mini - advice? | dunemaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-01-2009 03:11 PM |
Could my Mbox mini be causing the 6086 error? | flash0669 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-03-2008 07:21 PM |
6086 error with my Mbox mini | flash0669 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-30-2008 06:06 PM |
The Dreaded "-6086" error, please help, thanks. | simplymusicp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-20-2005 02:29 PM |
