Old 05-12-2009, 07:19 AM
shawnusa shawnusa is offline
Default Axiom Pro - Hypercontrol keyboard w/Protools 8 LE
Hello,
I'm new to the whole protools and midi world. I recently posted a thread or two on using BFD2 and other vitrual intrumnets via Protools and had trouble making sounds. Of course I was told I need some sort of Midi controller to create the midi tracks without doing it by hand. So, I purchased the Axiom Pro 61 keyboard with the hypercontrol abilities. Nice keyboard and would be nicer if I could get it to actually work.
I followed the M-Audio guide and setup Protools 8 LE to use it as a device. Not that difficult I would say 4 steps tops. The only think I could get it to do is play using the play button on the keyboard. Stop, sliders, keys, and everything else does nothing. No sound no control.
I'm using this on a Vista Laptop with the MBox2 unit and the Axiom Pro both via USB.
Protools is up todate on patches and I tried the latest Axiom drivers.
If someone could kindly take a few minutes to explain and maybe walk through the setup process would be great.
Thanks,
Shawn
Old 05-12-2009, 11:00 AM
DigiTechSupt's Avatar
Default Re: Axiom Pro - Hypercontrol keyboard w/Protools 8 LE
Can you tell us exactly how you have it configured in the Peripherals window?
Avid Audio Tech Support
Support FAQ
Old 05-12-2009, 12:10 PM
Sure,
In Setup- Peripherals then Midi controllers I have set in the #1 position
M-Audio Keybord
In the Recived from I have Axiom Pro Hypercontrol In
In the Send to I have Axiom Pro hupercontrol out
#ch's I have 8 set.
From here is claims it will work to control Pro Tools. Yet it controls nothing but play. Maybe I need to reset the keyboard even though I have not modified any settings on it yet.
Appricate your helping out.
Old 05-12-2009, 02:21 PM
Jared Jared is offline
Continue to follow up with me on this thread for troubleshooting this issue:
http://forums.m-audio.com/showthread.php?t=8845
Old 09-09-2009, 01:22 PM
DONNX DONNX is offline
Arrow Re: Axiom Pro - Hypercontrol keyboard w/Protools 8 LE
Hello everyone. I just got my M audio pro 61. The drivers are only up to PT 7.4???WThaaaa Does anyone know how I can make this controller work in PT 8 HD??? Transport controls, etc.? Where can I find a compatible PT 8 driver for it? Can't find it on M audio's website. Look on digidesign.com. No luck either. I remember seeing the video demo on Didgidesign.com. I said, cool!! got to get one. Now I got one. The damm thing doesn't control nada..
and I can't find the current drive anywhere. Please assist...PT 8 HD. Thanks
Old 09-09-2009, 05:20 PM
Bump
Old 09-09-2009, 05:34 PM
Mac or PC?
filosofem
Old 09-19-2009, 03:31 AM
mAC
Old 09-19-2009, 11:33 AM
Does 'M-Audio Keyboard' show in the Type drop-down of the MIDI Controllers>Peripherals setup?
If so select 'Axiom Pro HyperControl In' in the 'Receive From' field and 'Axiom Pro HyperControl Out' in the 'Send To' field.
filosofem
Old 09-20-2009, 03:46 PM
jackshocklee jackshocklee is offline
I can't use the hyper control functionality because my peripheral "receive from" menu doesn't have the hypercontrol option. It only has Axiom Pro, USB A In.
M-Audio Keybord
In the Recived from I have Axiom Pro USB A In (IT DOESN'T HAVE HYPERCONTROL!)
In the Send to I have Axiom Pro hypercontrol out
#ch's I have 8 set.
The Send is cool, but the receive only gives me one option. And that's for the USB A In, not HyperControl. Is there a setting on Pro Tools where I can make that option available? Thanks!
Jack
HyperControl for M-Audio Axiom AIR Keyboard Controllers? Blissful World Pro Tools 11 42 08-20-2014 08:23 PM
Axiom Pro/ProTools9/Hypercontrol problem clausiii MIDI 47 06-07-2011 02:25 PM
Axiom Pro 49 - Can't get HyperControl to work with Reason 5 Feghead MIDI 2 09-02-2010 01:24 PM
Axiom Hypercontrol vs D Command SaturnSound ICON & C|24 1 05-03-2010 03:06 PM
Axiom Pro 49 HyperControl option not showing up in Protools MP 8.0.1 on vista pc csharp35 Pro Tools M-Powered (Win) 2 10-19-2009 07:40 AM
