Old 01-09-2009, 10:49 AM
galliv galliv is offline
Default Mini Grand problem
I've just reinstalled for the 4th time Pt8 on a G5 2x2.5 w/8gb ram (after an upgrading from 4gb)... Now seems to work pretty well under 10.5.5 (but I didn,t install any3rd parts plugs yet...) but I can't use Mini Grand. No way to let it sound! It loads the banks and it receives midi, but doesn't sound.... And when I use the keybord in the plugin window, Pt crash...
Anyone has some ideas?
Thank you very much in advance!
Old 01-10-2009, 08:18 AM
Aan22 Aan22 is offline
Default Re: Mini Grand problem
Yes ! Please help me out I have the same problem, my is on Windows XP pro
Old 01-10-2009, 09:17 AM
blackbirdstudio blackbirdstudio is offline
Mini grand works for me if i use a separate midi track to trigger the instrument track with mini grand inserted on it..
The organ one works straight up on an instrument track..
cheers
Dave
2.66 Ghz Quad-Core Intel Xeon, OS 10.6.3
HD3 Accel, Control 24, PT 8.1 cs1
Old 01-10-2009, 11:01 AM
hitshack hitshack is offline
How does the Mini Grand sound for those that can get it to work?
Old 01-10-2009, 11:39 AM
I tried everything.... An instance of MG on a instrument track, an instance on audio track triggered by midi track, stereo, mono, everything... no way...
No audio signal come out... (but it receives midi!)
Please, help!!!
Old 01-11-2009, 06:30 PM
I tried it all it's does not works it's crashed all the time . please help !
core 2 CPU 2.13 GHz Service Pack 3 4 GB 2 hard drives .
Amature like me need help , thank you guys
Old 01-12-2009, 07:28 AM
ianmiller ianmiller is offline
Sometimes you have to add a physical audio input to an instrument track to make it work. Get over the fact that it makes little sense and just add a physical audio input and you may be surprised to actually get audio sounding!!
Old 01-12-2009, 08:19 AM
DigiTechSupt's Avatar
Please, help!!!
We're going to need a more detailed description of exactly what you're doing, step by step, as well as a complete description of your system.
Please see the Help Us Help You thread for details - you may also want to take a look at the General Troubleshooting thread, as it may have a solution for you.
Avid Audio Tech Support
Support FAQ
Old 01-12-2009, 12:06 PM
woodsdenis woodsdenis is offline
Is this a windoze machine .If so you might get more help on the Windows
TDM forum. Mini Grand works fine here.It might be a Windows bug
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
VI (specifically Mini Grand) Volume Level Problem / Issue guitarman6 Virtual Instruments 3 01-05-2012 10:27 PM
air mini grand kidboy500 macOS 5 10-22-2011 01:02 AM
Mini Grand : Phase / Correlation problem ? Madien Virtual Instruments 9 10-11-2011 03:42 AM
mini grand and NI akousik piano problem temb0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-08-2009 01:05 AM
Mini Grand VI Fullsound Recording Pro Tools TDM Systems (Win) 4 03-15-2009 07:49 PM
